Deadtime 6pwm - hacking 10$ 36v/500w bldc controller to run simplefoc
Hi, I’m trying to come up with 4wd hoverboard motor drive for a big rc car as cheap as possible.
I am planing on removing the main IC from a board similar to this Low cost brushless motor drivers (BLDC) for DIY projects | Work-is-Playing
And connect respective pins to a blue/blackpill.
The board has ir2101 driver. The board is rated for 36v 500w (probably a bit exagerated) and costs less than 10$
Is deadtime implemented in 6pwm mode or I’d need to come up with an external delay circuit?
Any thoughts and comments on this approach are welcomed.
Hey @Aleksandar_Markovic,
This seems interesting.
I have had some experience with this board few years ago, before simplefoc era :smiley:
And I remember it being frustrating because the board has implemented some ramping algorithms or something like that, and by removing the IC I was left with a lot of unknowns :smiley:
The 6pwm mode has dead-time implemented:
I’ve called it a dead-zone. It is essentially the same thing, just I’ve made a choice for it to be a percentage of the duty cycle as opposed to the time delay. But the mapping in between them is easy.
@Owen_Williams will be able to give you much more info about the hoverboard motors, he has become a real expert! :smiley:
Let us know how it goes.
I’ve got a couple of those boards but haven’t attempted to desolder. I was hoping that the chip would be reprogrammable but I don’t think it can. I’d be interested to hear how you get on!
At the moment I’m using 2x stm32g431 discovery kit for drones to drive two hoverboard motors. They are a little bit underpowered for hoverboard motors and hard to solder but are a reasonable match. I’m looking for a better dual motor solution and might have to resort to printing my own board.
@Antun_Skuric @Owen_Williams Thank you for answering this quickly :smiley:
I have a few of these boards and I’ll give it a try and report back the results as soon as I get my hands on few blue/black pills.
Hi, I was impatient and destroyed the IC pads, but managed to solder the wires directly to IR2101 pins.
I have a few Arduinos laying around and thought to test the idea but I’m not sure about the code - I would like to at least avoid frying the board on the first try.
@Antun_Skuric @Owen_Williams Does this code look ok to you just for testing (for Arduino ProMini or Nano)?
   BLDCDriver6PWM driver = BLDCDriver6PWM(5, 6, 9,10, 3, 11);
   float target_velocity = 10;
 driver.pwm_frequency = 32000;
 driver.voltage_limit = 12;
 driver.dead_zone = 0.05;
 motor.voltage_limit = 3;
 motor.velocity_limit = 20;
 motor.controller = ControlType::velocity_openloop;
Haha :smiley:
The code seems fine. Just make sure to respect high/low pair pins HIGH/LOW 5/6, 9/10, 3/11
Also, I would limit the voltage even more to 1V maybe, start small :slight_smile:
If you have a bench power supply - set it to 0.5A limit - that way it’ll be (almost) impossible to melt your driver!
Thanks a bunch. I have no equipment :slight_smile:
I tested from ATX PSU instead of batteries and seems to work intermittently - I see the “misbehavior” Owen mentions in his tuning video but I’m guessing the reason is not the same since sometimes the PSU shuts down https://www.youtube.com/watch?v=ufMs83Y3sXg
That might be caused by my soldering “skills”
I’ll have some more spare time during the weekend to try to make this work correctly.
Lowered voltage to 3 and velocity to 1 and it’s turning smoothly in openloop wit a current draw of less than .5 amps - shutting down seems to be a PSU issue, it’s dying.
Cool, you have some videos? :wink:
Please share with us the connection diagram, how did you solder everything? :smiley:
I’ll take some pictures and make a short video.
I bumped into JY01 datasheet in English (the removed IC - probably translated), and there’s not much I can draw but I can share the pins diagram and schematics (can’t upload PDF here) for now.
I was planning on wiring it to the JY01 IC pads, but I ended soldering them directly to IR2101 pins
This looks like the board I have
I’ll post pics and videos in a few days.
This is the wiring - you can clearly see the soldering “skills” at work
I’ve cleaned it a little bit since I took the photo, but it’s still a mess.
AT/AB - pin 5/6
BT/BB - 9/10
CT/CB - 3/13 (the markings for this pair is wrong on the photo)
It’s easier to cleanly remove the IC and solder on pads, but I missed that chance. There are no components between JY01 IS and the mosfet drivers, so it’s basicaly the same.
I have hooked up the hall sensors directly to the Arduino (pro mini) using the internal pullup and software interrupts. Still running it in an open loop, and the sensors output values that make sense.
As I mentioned earlier, I have no equipment to precisely test anything, but my multimeter doesn’t ever seem to register more than 3.8-3.9v on the hall sensor, and sometimes it gives barely 2,5V, so I guess that pull-up is a way to go.
I’ll redo the soldering when I get my hands on copper enameled wire, connectors and some mounting for the connector to replace the UTP cable and make this usable for me.
I’ll post a video of this setup working when I get the chance, but I warn you - it’s ugly :slight_smile:
Currently running with:
target_velocity = 2;
Open-loop is pulling around 2 amps at 12V. The mosfets are getting warm after a few minutes which might be a shoot-through issue due to the wrong dead-zone setting. I’ll have to test different values and take temp readings on mosfets as I have no scope to debug this properly.
Voltage control for the same settings is pulling 0.2 - 0.3 amps but reached almost 1.5 amps when I applied mechanical load to the wheel. I could not hold the wheel long enough to see if it will pump up the temp on mosfets as it did in open loop, but I’ll get to that as well.
I’d say that this works reasonably well for now, and is dirt cheap.
Another cheap approach could be to use BTS7960B drivers, and that wouldn’t require any soldering skills - 3 boards could drive 2 motors, and are rated at 42 amps, 5-27V, but I don’t have them.
I’ll post back the videos when I get the chance.
Very cool!
I’m happy you found a solution and that it works :smiley:
BTS7960B are great ics and they are very similar to
IFX007T. Very powerful and simple to handle.
I’m actually considering both for the higher power version of the simplefoc shield. :smiley:
Bts7960 can be used,I have done experiments for this
This is a test video:
Cool!
We have already seen your video!
I think it’s a great idea.
What are your impressions?
When starting, I feel that the current is large. For a high-power motor, the starting current will almost reach 90% of the current limit value. And then leveled off. The position closed-loop mode is normal, and the speed closed-loop mode, when the speed exceeds 90rpm, the current will increase to the current limit value, and the bts7960 will be very hot. Of course, maybe I use a big motor, which is the steering motor of the car. For ordinary small motors, there is no problem, and there is no time to test the torque mode. It is suggested to add current detection to the library.
Are you actually using the simplefoc library?
Yes, I use the version 1.6 library. Maybe I can test it again with the latest version
