Custom bldc running torque mode not spinning
Got a custom bldc motor with a custom drv8353 motor driver using hall sensors.
Motors spins good in open loop, but just vibrates after setup when running in torque mode.
I’ve attached torque mode code.
Hall sensor test code look good, when rotating a full circle reading is 6.28
MOT: Align sensor.
MOT: Monitor enabled!
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: sensor_direction==CW
MOT: PP check: OK!
MOT: Zero elec. angle: 5.24
MOT: No current sense.
MOT: Ready.
Motor ready.
Set the target voltage using serial terminal:
 * you a way to control motor torque by setting the voltage to the motor instead of the current.
HardwareSerial Serial1(USART1);
#define INH_A PB0
#define INH_B PA7
#define INH_C PA6
#define EN_GATE PA8
BLDCDriver3PWM driver = BLDCDriver3PWM(INH_A, INH_B, INH_C, EN_GATE);
// hall sensor instance
HallSensor sensor = HallSensor(PB14, PB13, PB12, 14);
// channel A and B callbacks
void doA(){sensor.handleA();}
void doB(){sensor.handleB();}
void doC(){sensor.handleC();}
// voltage set point variable
float target_voltage = 1;
Commander command = Commander(Serial1);
  driver.voltage_limit = 4;
  // link driver
    motor.voltage_limit = 4;   // [V]
  // aligning voltage
  Serial1.begin(115200);
  motor.useMonitoring(Serial1);
  // align sensor and start FOC
  Serial1.println(F("Motor ready."));
  Serial1.println(F("Set the target voltage using serial terminal:"));
  // Arduino UNO loop  ~1kHz
  // Bluepill loop ~10kHz
  motor.move(target_voltage);
//motor.monitor();
Hi @nitram321 , welcome to SimpleFOC!
One question I have: is the motor really 14 pole-pairs, or is it 14 poles, meaning 7 pole-pairs? If so you should change the initialisation of BLDCMotor accordingly…
although it is saying PP check OK! so probably its correct.
Can you perhaps also change the modulation to FOCModulationType::SinePWM for now, and change the motor voltage limit to be half the driver voltage limit? These parameters should lead to more sine-like waveforms.
Hi @runger
thanks for your replay.
It was a mechanical error on our part. Hall sensors was placed incorrectly to create the normal “binary” output. its working now, but there is another issue with initializing current sensing. Will create another topic.
