I went through the JLCPCB assembly process and found during part selection that the latest EasyEDA PCB design files seem to incorrectly populate the INA240 parts for current sense and even have the v2.x current sense resistors RCS1 & RCS2 on the PCB layout.
which leads to PCB files with the INA240 part and v2.x RCS1 and RCS2 current sense resistors? The PCB silkscreen shows v3.7
Is the documentation page linking the wrong EasyEDA project to use? Or am I missing something? I found this when trying to populate the RSC1/2 resistors and realized they shouldn’t be there. Pictures of assembled v3.x boards do not have the RCS1/RCS2 resistors in the layout, so I’m confused.
thanks for reporting it! The next version of the shield is switching back to INA current sense amps, so maybe this is a documentation bug. We‘ll look into it!
Thanks, it might be the documentation links to the EasyEDA project currently being used to develop the next version, the silkscreen said v3.7 which is what first indicated it probably was the wrong board.
BTW, I’ve wanted a board with the DRV8313 and the INA240, is the board currently visible at https://oshwlab.com/the.skuric/simplefocshield_copy_copy complete or mostly complete and usable if I made it? Or is it still in progress with additional items to complete?
Hi guys!
Yep the new version of the v3.7 is a lot different from the v3.2.
But the fabrication part is more or less the same.
The github page still has the v3.2 on it and I’ll update them so.
The v3.7 is a stable model. It’s well tested and it’s gonna be next release (standard) release going to the github page.
That being said, the v4 version with drv8316 will soon be available:
I’ve just ordered it for testing and this will be the next one that will be available to buy I think. At least officially.
Thank you for the reply and update. A board with the drv8316 will be great, thanks for mentioning this, I'll try them once the design is finalized.
Hi @Antun_Skuric, I'm after a v3 shield with DRV8313 + INA240 — for my gimbal motor the INA240's low-current resolution matters vs the ACS712 on v3.2. I tried ordering from the EasyEDA project here, but the BOM is empty and status is "Ongoing," so it's not orderable. The description also says ACS712, conflicting with the earlier INA240 + v3.7 report. 1. Is there a complete, orderable file (Gerber+BOM) for the DRV8313+INA240 version, or an ETA? 2. Final v3.7 sense chip — INA240 or ACS712? If INA240, which gain (20/50/100)? 3. v4 timeline — worth waiting for? Thanks!
– twfryHi @Antun_Skuric, I'm after a v3 shield with DRV8313 + INA240 — for my gimbal motor the INA240's low-current resolution matters vs the ACS712 on v3.2. I tried ordering from the EasyEDA project here, but the BOM is empty and status is "Ongoing," so it's not orderable. The description also says ACS712, conflicting with the earlier INA240 + v3.7 report. 1. Is there a complete, orderable file (Gerber+BOM) for the DRV8313+INA240 version, or an ETA? 2. Final v3.7 sense chip — INA240 or ACS712? If INA240, which gain (20/50/100)? 3. v4 timeline — worth waiting for? Thanks!
– Gwangyeol_Byeon
