issues reading the total current sent to the motor. My set up consists of a GM3506 Gimbal Motor (5.6ohms) a MKS Dual FOC board and an esp32 dev board. According to the schematics the MKS board has a 0.01ohm resistor and a op amp gain of 50. I set that up using InlineCurrentSense(0.01f, 50.0f, 35, 34); but when I call getDCCurrent() it is inaccurate. From following tests I noted that the power supply current was 0.27amps while the getDCCurrent() read about 1.2 amps. I also tried at a current of 1.10 amps from the power supply and the getDCCurrent() read about 2.4 amps. So it’s consistently reading higher than the real current. I cant figure out what is going on. Ive tried messing with th eInlineCurr entSense(0.01f, 50.0f, 35, 34); values just in case and also changing the the gain_b and gain_a to -1. I also switched out the esp32 incase its ADC was the problem but to no avail. Please I would appreciate any help with this.
Notes: using Simple FOC library 2.3.2
code for reference:
MagneticSensorSPI sensor2 = MagneticSensorSPI(AS5147_SPI, 15);
BLDCMotor motor2 = BLDCMotor(11);
BLDCDriver3PWM driver2 = BLDCDriver3PWM(26, 27, 14, 12); //MKS esp32
InlineCurrentSense current_sense2 = InlineCurrentSense(0.01f, 50.0f, 35, 34); //MKS dual foc esp32
// Motor and Actuator 2 parameters
float target_angle_m2 = 0; // Radians - motor
float target_angle_a2 = 0; // Radians - actuator
float angle_a2; // Radians
float velocity_a2; // Radians per second
float angle_offset_m2 = 0; // Radians
float joint_stop_a2 = 15 * (PI / 180.0); // Radians - Joint stop angle from zero
unsigned long homingTime;
void doTarget(char* cmd) {
command.scalar(&target_angle_a2, cmd);
void Homing() {
bool homing_m2 = true; //when homing true, false when home has been found
homingTime = millis();
target_angle_m2 = motor2.shaft_angle;
motor2.move(target_angle_m2);
while (homing_m2) {
motor2.loopFOC();
if (millis() - homingTime > 50) {
//Motor 2 Homing
if (abs(motor2.voltage.q) < 1.5 && homing_m2) {
target_angle_m2 -= .3;
} else if (homing_m2) {
angle_offset_m2 = motor2.shaft_angle;
homing_m2 = false;
target_angle_m2 = .5 + angle_offset_m2;
motor2.loopFOC();
Serial.print("Homing Found M2");
Serial.print(angle_offset_m2);
Serial.print(" ");
Serial.print(" M2 Tθ:");
Serial.print(target_angle_m2);
Serial.print(" V:");
Serial.println(motor2.voltage.q);
//Serial.print(" A:");
//Serial.println(current_sense1.getDCCurrent()); // total current in Amps
sensor2.init();
motor2.linkSensor(&sensor2);
driver2.pwm_frequency = 20000;
driver2.voltage_power_supply = 24;
driver2.voltage_limit = 24; // max voltage to motor
driver2.init();
motor2.linkDriver(&driver2);
current_sense2.linkDriver(&driver2);
current_sense2.init();
//current_sense2.gain_b *= -1;
//current_sense2.gain_a *= -1;
motor2.linkCurrentSense(¤t_sense2);
motor2.foc_modulation = FOCModulationType::SpaceVectorPWM;
//motor.torque_controller = TorqueControlType::foc_current;
//motor.current_limit = 1; // Amp limit
motor2.controller = MotionControlType::angle;
// contoller configuration
motor2.PID_velocity.P = .1;
motor2.PID_velocity.I = 2;
motor2.PID_velocity.D = 0;
motor2.voltage_limit = 12; //8
motor2.LPF_velocity.Tf = 0.01f;
// angle P controller
motor2.P_angle.P = 10;
motor2.velocity_limit = 190;
motor2.useMonitoring(Serial);
motor2.init();
// align sensor and start FOC;
motor2.initFOC();
// Homing %%%%%%%%%%%%%%%%%%%%%%
Homing();
//PhaseCurrent_s currents = current_sense.getPhaseCurrents();
motor2.loopFOC();
target_angle_m2 = target_angle_a2 * 9;
motor2.move(target_angle_m2 + angle_offset_m2 + (joint_stop_a2 * 9));
// monitor angles & velocity at ~10 Hz
static unsigned long t_last = 0;
if (millis() - t_last > 150) {
t_last = millis();
angle_a2 = (motor2.shaft_angle - angle_offset_m2) / 9 - joint_stop_a2;
velocity_a2 = motor2.shaft_velocity / 9;
// Actuator Stats:
Serial.print(" θ2:");
Serial.print(angle_a2, 3);
Serial.print(" ω2:");
Serial.print(velocity_a2, 3);
Serial.print(" Vq2:");
Serial.print(motor2.voltage.q, 2);
Serial.print(" A2:");
Serial.print(current_sense2.getDCCurrent()); // total current in Amps
Serial.println();
So what you're saying is that the motor windings are essentially getting a lower voltage than what I'm driving them at, so more current can go through? Wouldn't a difference of one amp be a bit excessive though?
– Max_MartinNot at all. Motor current can be many times higher than power supply current, especially with a relatively high power supply voltage like 24V.
– dekutree64The power should be conserved, you can try reading the q component of the voltage and see if the voltage*current of the motor corresponda roughly to the power supply ones.
– Antun_SkuricGreat thank you! I think it's working well now. I am just having issues tuning the q and d pid current parameters in foc_current while controlling the velocity. I get very small jittering/whining of the motor even at zero velocity if I have the currents P terms over 0.5. Since P is so small, it runs mostly on the I term, meaning there is a delay in changing velocity as the I term winds up. How can I get rid of this jitter and increase the currents P terms
– Max_MartinIf you just want it to relax instead of fighting to maintain zero speed (which usually results in small oscillation, as you're experiencing), you can switch to torque control mode and set target 0.
– dekutree64
