We’re having issues getting lowside current sense to work.
Current sense init failed!
Code generated with SimpleFOCGenerator
Any obious errors?
//HardwareSerial Serial1(USART1);
// BLDC motor instance BLDCMotor(polepairs, (R), (KV))
// BLDC driver instance BLDCDriver3PWM(phA, phB, phC, (en))
BLDCDriver3PWM driver = BLDCDriver3PWM(PB0, PA7, PA6, PA8);
// position / angle sensor instance HallSensor(hallA, hallB , hallC , pole pairs)
HallSensor sensor = HallSensor(PB13, PB14, PB12, 14);
void doA(){sensor.handleA();}
void doB(){sensor.handleB();}
void doC(){sensor.handleC();}
// lowside current sense instance LowsideCurrentSense(R, gain, phA, phB, (phC))
LowsideCurrentSense currentsense = LowsideCurrentSense(0.007, 10, PA0, PA1, PA2);
// commander instance
void doTarget(char* cmd){command.motion(&motor, cmd);}
// start serial
// USE_EXTERN is default (1k - 5k recommended), change to USE_INTERN if needed
// initialize sensor
// enable Hall effect interrupts
// link sensor to motor
// set power supply voltage
// set driver voltage limit, this phase voltage
driver.voltage_limit = 4;
// initialize driver
// link driver to motor
// link driver to current sense
currentsense.linkDriver(&driver);
// set torque control type to voltage (default)
// set FOC modulation type to sinusoidal
// velocity PID controller
motor.PID_velocity.P = 0.2;
motor.PID_velocity.I = 2;
// set motor voltage limit, this limits Vq
motor.voltage_limit = 2;
// set motor velocity limit
motor.velocity_limit = 20;
// set motor current limit, this limits Iq
motor.current_limit = 2;
// use monitoring
// initialize current sensing and link it to the motor
// https://docs.simplefoc.com/inline_current_sense#where-to-place-the-current_sense-configuration-in-your-foc-code
currentsense.init();
if (currentsense.init()) Serial1.println("Current sense init success!");
else{
Serial1.println("Current sense init failed!");
return;
motor.linkCurrentSense(¤tsense);
// align sensor and start FOC
// add command to commander
command.add('M', doTarget, "target");
// this function can be run at much lower frequency than loopFOC()
// significantly slowing the execution down
What, if you use FOC_current instead?
Sorry for a very late reply. Had to get the motor working so used trapezoidal commutation, would like to get FOC working.
Don’t see why foc_current would make any difference as many example codes does not use foc_current. Did try and it made no difference.
MCU is STM32F103CBU with DRV8353RH motor driver.
PA0 and PA1 is connected to sense A and sense B on DRV8353RH
Output from terminal below code.
const int INH_A = PB0;
const int INH_B = PA7;
const int INH_C= PA6;
#define EN_GATE PA8
BLDCDriver3PWM driver = BLDCDriver3PWM(INH_A, INH_B, INH_C, EN_GATE);
// hall sensor instance
HallSensor sensor = HallSensor(PB12, PB13, PB14, 14);
// channel A and B callbacks
Commander command = Commander(Serial1);
LowsideCurrentSense cs = LowsideCurrentSense(0.007f, 10.00f, PA0, PA1, _NC);
driver.voltage_power_supply = 48;
driver.pwm_frequency = 15000;
cs.linkDriver(&driver);
// align voltage
// control loop type and torque mode
motor.motion_downsample = 0.0;
// velocity loop PID
motor.PID_velocity.I = 5.0;
motor.LPF_velocity.Tf = 0.02;
// angle loop PID
motor.P_angle.P = 20.0;
motor.LPF_angle.Tf = 0.0;
// current q loop PID
motor.PID_current_q.P = 3.0;
motor.PID_current_q.I = 100.0;
motor.LPF_current_q.Tf = 0.02;
// current d loop PID
motor.PID_current_d.P = 3.0;
motor.PID_current_d.I = 100.0;
motor.LPF_current_d.Tf = 0.02;
// Limits
motor.velocity_limit = 100.0; // 100 rad/s velocity limit
motor.voltage_limit = 12.0; // 12 Volt limit
motor.current_limit = 2.0; // 2 Amp current limit
// monitoring port
Serial1.begin(115200);
motor.useMonitoring(Serial1);
motor.monitor_variables = _MON_CURR_Q | _MON_CURR_D; // monitor the two currents d and q
motor.monitor_downsample = 1000;
// initialise motor
cs.init();
cs.skip_align = true;
// driver 8302 has inverted gains on all channels
//cs.gain_a *=-1;
//cs.gain_b *=-1;
//cs.gain_c *=-1;
motor.linkCurrentSense(&cs);
motor.initFOC(4.19, CCW);
motor.target = 0;
// define the motor id
Serial1.println(F("Full control example: "));
Serial1.println(F("Run user commands to configure and the motor (find the full command list in docs.simplefoc.com) \n "));
Serial1.println(F("Initial motion control loop is voltage loop."));
Serial1.println(F("Initial target voltage 2V."));
// display the currents
17:27:22.942 -> MOT: Monitor enabled!
17:27:22.942 -> MOT: Init
17:27:23.437 -> MOT: Enable driver.
17:27:24.472 -> MOT: Align sensor.
17:27:24.472 -> MOT: Skip dir calib.
17:27:24.472 -> MOT: Skip offset calib.
17:27:24.967 -> MOT: Init FOC error, current sense not initialized
17:27:24.967 -> MOT: Init FOC failed.
17:27:24.967 -> Full control example:
17:27:24.967 -> Run user commands to configure and the motor (find the full command list in docs.simplefoc.com)
17:27:24.967 ->
17:27:24.967 -> Initial motion control loop is voltage loop.
17:27:24.967 -> Initial target voltage 2V.
you should call cs.init();
