Current_sense error + drv8302 + esp32-S3
Hello everyone,
I am working on a custom BLDC motor controller based on an ESP32-S3 and a DRV8302 using SimpleFOC. I am using shunts to measure current on phases A and B only. Phase C does not have a current sensor (no shunt). When running the code, I get this error:
CS: Switch A-(C)NC
CS: Err B - all currents same magnitude!
I’m using BGM-5208-200 bldc motor. Could someone please help me with this issue?
Here is my code:
// Motor instance
// Driver instance
BLDCDriver6PWM driver = BLDCDriver6PWM(7, 8, 14, 9, 16, 15, 6);
// Magnetic sensor instance
MagneticSensorSPI AS5x4x = MagneticSensorSPI(10, 14, 0x3FFF);
// DRV8302 board has 0.005 Ohm shunt resistors and a gain of 12.22 V/V
LowsideCurrentSense cs = LowsideCurrentSense(0.005f, 40.0f, 17, 18, _NC);
// Target velocity
float target_velocity = 30;
// Commander instance
// Commander command functions
void onTarget(char* cmd) {
  command.scalar(&target_velocity, cmd);
void doMotor(char* cmd) {
  command.motor(&motor, cmd);
  // Sensor init
  pinMode(5, OUTPUT);
  digitalWrite(5, HIGH);
  AS5x4x.init();
  motor.linkSensor(&AS5x4x);
  // Driver config
  driver.pwm_frequency = 50000;
  driver.dead_zone = 0.03;
  driver.voltage_power_supply = 19;
  driver.voltage_limit = 19;
  // driver.voltage_limit = 50;
  motor.voltage_limit = 11;
  motor.velocity_limit = 300;
  cs.linkDriver(&driver);
  motor.voltage_sensor_align = 2.5;
  motor.current_limit = 200;
  // PID velocity
  motor.PID_velocity.P = 0.8;
  motor.PID_velocity.I = 2;
  motor.PID_velocity.output_ramp = 10;
  // Velocity filter
  motor.LPF_velocity.Tf = 0.1;
  // Current limit
  // motor.current_limit = 10;
  // Motor + FOC init
  cs.init();
  // drv8302 has inverted gains on all channels
  cs.gain_a *= -1;
  cs.gain_b *= -1;
  cs.gain_c *= -1;
  motor.linkCurrentSense(&cs);
  // Monitoring variables
  motor.monitor_variables = _MON_TARGET | _MON_VEL | _MON_VOLT_Q;
  motor.monitor_downsample = 500;
  // Add target command 'T'
  command.add('T', onTarget, "target velocity");
  command.add('M', doMotor, "Motor");
Thank you !
4
Hi
a schematic could be usefull.
That the schematic of my board :
thx…
are you intentionnaly hardly filter the analog Output?
I mean… wow! 2.2µF ….I see 2.2nF in typical app…
best regards
Oh you are right I didn’t paid attention about this! That’s an error of mine (I developed this board very quickly for a first PoC ) . It can maybe explain why I have the same magnitude because the filtering is very too hard. I’m going to test without these capacitor because I can’t change it for the moment.
Thank !
