SimpleFOC mainly depends on the MCU in which you run it. I assume that you are using a board like this one or similar.
If this is the case as far as you get running SimpleFOC in your MCU it will work. If your board has an integrated MCU I can not tell you.
Here you have, as example, a custom board to run SimpleFOC board using IFX007T, so IFX007T are perfectly suitable.
Regards !!
