Hello and thank you for this awesome project,
I’m planning to control three BLDC motors (iFlight iPower GM4108H-120T) using a single ESP32 and 3 simplefocmini for each motor. I’ve seen that the ESP32 provides 2 MCPWM units and LEDC PWM.
Can I mix MCPWM and LEDC, for example:
control two motors with MCPWM, and
control one motor with LEDC?
If so, will they be well synchronized? Or would it be better in this case to use only LEDC, since it can support up to 9 PWM outputs?
Project context : a simple 3 mecanum robot mobile base
Thank you in advance !
