That’s not needed, you can get it working using the generic F303RE or possibly the nucleo 303RE board config… unfortunately I can’t tell you anymore because it seems ArduinoIDE does not remember this information from when I last ran these sketches.
I have the following in my sketch which may help you, but its been a long time since I ran it so YMMV:
#include "arduino.h"
#include "Wire.h"
#include "SPI.h"
#include "SimpleFOCDrivers.h"
#include "encoders/as5048a/MagneticSensorAS5048A.h"
#define V_PSU 8
#define V_LIMIT 8
#define V_INIT_LIMIT 8
// GMBL02V1 pins
#define PIN_LED PA7
#define PIN_MOSI PC12
#define PIN_MISO PC11
#define PIN_SCK PC10
#define PIN_nCS1 PB8
#define PIN_nCS2 PB9
#define PIN_nCS3 PB10
#define PIN_M1_U PC0
#define PIN_M1_V PC1
#define PIN_M1_W PC2
#define PIN_M1_EN PC13
#define PIN_M1_FLT PC3
#define PIN_M1_SNS PB0
#define PIN_M2_U PA0
#define PIN_M2_V PA1
#define PIN_M2_W PA2
#define PIN_M2_EN PC14
#define PIN_M2_FLT PA3
#define PIN_M2_SNS PB11
#define PIN_M3_U PC6
#define PIN_M3_V PC7
#define PIN_M3_W PC8
#define PIN_M3_EN PC15
#define PIN_M3_FLT PC9
#define PIN_M3_SNS PB14
SPISettings myspisettings(1000000, BitOrder::MSBFIRST, SPI_MODE1);
MagneticSensorAS5048A sensor1(PIN_nCS1, false, myspisettings);
BLDCMotor motor1 = BLDCMotor(7);
BLDCDriver3PWM driver1 = BLDCDriver3PWM(PIN_M1_U, PIN_M1_V, PIN_M1_W, PIN_M1_EN);
MagneticSensorAS5048A sensor2(PIN_nCS2, false, myspisettings);
BLDCMotor motor2 = BLDCMotor(7);
BLDCDriver3PWM driver2 = BLDCDriver3PWM(PIN_M2_U, PIN_M2_V, PIN_M2_W, PIN_M2_EN);
MagneticSensorAS5048A sensor3(PIN_nCS3, false, myspisettings);
BLDCMotor motor3 = BLDCMotor(7);
BLDCDriver3PWM driver3 = BLDCDriver3PWM(PIN_M3_U, PIN_M3_V, PIN_M3_W, PIN_M3_EN);
float target1, target2, target3;
void loadAlignment() {
// TODO load from EEPROM/FLASH
void initMotors() {
pinMode(PIN_nCS1, OUTPUT);
digitalWrite(PIN_nCS1, 1);
sensor1.init();
motor1.linkSensor(&sensor1);
delay(10);
pinMode(PIN_nCS2, OUTPUT);
digitalWrite(PIN_nCS2, 1);
sensor2.init();
motor2.linkSensor(&sensor2);
delay(10);
pinMode(PIN_nCS3, OUTPUT);
digitalWrite(PIN_nCS3, 1);
sensor3.init();
motor3.linkSensor(&sensor3);
delay(10);
driver1.voltage_limit = V_LIMIT;
driver1.voltage_power_supply = V_PSU;
driver1.init();
motor1.linkDriver(&driver1);
driver2.voltage_limit = V_LIMIT;
driver2.voltage_power_supply = V_PSU;
driver2.init();
motor2.linkDriver(&driver2);
driver3.voltage_limit = V_LIMIT;
driver3.voltage_power_supply = V_PSU;
driver3.init();
motor3.linkDriver(&driver3);
motor1.voltage_limit = motor2.voltage_limit = motor3.voltage_limit = V_LIMIT;
motor1.voltage_sensor_align = motor2.voltage_sensor_align = motor3.voltage_sensor_align = V_INIT_LIMIT;
motor1.controller = motor2.controller = motor3.controller = MotionControlType::angle;
motor1.PID_velocity.P = motor2.PID_velocity.P = motor3.PID_velocity.P = 0.2;
motor1.PID_velocity.I = motor2.PID_velocity.I = motor3.PID_velocity.I = 10;
motor1.PID_velocity.D = motor2.PID_velocity.D = motor3.PID_velocity.D = 0;
motor1.PID_velocity.output_ramp = motor2.PID_velocity.output_ramp = motor3.PID_velocity.output_ramp = 1000;
motor1.LPF_velocity.Tf = motor2.LPF_velocity.Tf = motor3.LPF_velocity.Tf = 0.01;
motor1.P_angle.P = motor2.P_angle.P = motor3.P_angle.P = 20;
motor1.init();
motor1.initFOC();
motor2.init();
motor2.initFOC();
motor3.init();
motor3.initFOC();
// TODO store motor initialization params and only re-init if we can't load them (and provide a command to reset them)
motor1.sensor_offset = motor1.shaftAngle();
motor2.sensor_offset = motor2.shaftAngle();
motor3.sensor_offset = motor3.shaftAngle();
target1 = target2 = target3 = 0.0;
motor1.disable();
motor2.disable();
motor3.disable();
void doTarget1(char* cmd) { command.scalar(&target1, cmd); }
void doTarget2(char* cmd) { command.scalar(&target2, cmd); }
void doTarget3(char* cmd) { command.scalar(&target3, cmd); }
void doTargetAll(char* cmd) { doTarget1(cmd); doTarget2(cmd); doTarget3(cmd); }
void doMotor1(char* cmd) { command.motor(&motor1, cmd); }
void doMotor2(char* cmd) { command.motor(&motor2, cmd); }
void doMotor3(char* cmd) { command.motor(&motor3, cmd); }
void setMotorZeros(char* cmd) {
Serial.println("Set zero position.");
void startStop(char* cmd) {
int motnum = 0;
if (strlen(cmd)>1) motnum = cmd[0] - '0';
if (motnum==0||motnum==1) {
if (motor1.enabled)
motor1.disable();
else
motor1.enable();
if (motnum==0||motnum==2) {
if (motor2.enabled)
motor2.disable();
else
motor2.enable();
if (motnum==0||motnum==3) {
if (motor3.enabled)
motor3.disable();
else
motor3.enable();
void storeAlignment(char* cmd) {
// TODO store to EEPROM/FLASH
pinMode(PIN_LED, OUTPUT);
digitalWrite(PIN_LED, 1); // switch on lED for initialization
while (!Serial);
SPI.setMOSI(PIN_MOSI);
SPI.setMISO(PIN_MISO);
SPI.setSCLK(PIN_SCK);
Serial.println("Motor initialization...");
initMotors();
command.add('a', doTarget1, "target1 position");
command.add('b', doTarget2, "target2 position");
command.add('c', doTarget3, "target3 position");
command.add('d', doTargetAll, "all motors to position");
command.add('s', startStop, "enable/disable motors");
command.add(' ', startStop, "enable/disable motors");
command.add('A', doMotor1, "motor 1 commands");
command.add('B', doMotor2, "motor 2 commands");
command.add('C', doMotor3, "motor 3 commands");
command.add('Z', setMotorZeros, "set zero positions");
command.add('W', storeAlignment, "store zero positions");
Serial.println("Motor initialization complete.");
digitalWrite(PIN_LED,0);
long last;
motor1.loopFOC();
motor1.move(target1);
motor2.loopFOC();
motor2.move(target2);
motor3.loopFOC();
motor3.move(target3);
// TODO report status & position on Serial
// read it quickly or we could lose turn count
float a1 = motor1.shaft_angle;
float a2 = motor2.shaft_angle;
float a3 = motor3.shaft_angle;
if (sensor1.isErrorFlag()) {
Serial.println("S1ERR");
sensor1.clearErrorFlag();
if (sensor2.isErrorFlag()) {
Serial.println("S2ERR");
sensor2.clearErrorFlag();
if (sensor3.isErrorFlag()) {
Serial.println("S3ERR");
sensor3.clearErrorFlag();
// print once per second, to keep it readable
long ts = millis();
if ((ts-last)>=1000) {
last = ts;
Serial.print(a1,4);
Serial.print("\t");
Serial.print(a2,4);
Serial.print("\t");
Serial.println(a3,4);
