Choosing a correct microcontroller for FOC_current torque controll and Arduino IDE
Hello everyone!
I’m developing a bldc motor controller and looking for a reliable microcontroller to run FOC_current mode, and to be able to program it through Arduino IDE. Preferebly, the size of the microcontroller should be the size of a Arduino Nano, or STM32 Nucleo 32, becouse my board has a layout that fits this size. I have seen the Supported Hardware section on the web site, but i am looking for something that was already tried out, to be as sure as possible, that it is going to work smoothly.
In the beggining i was using a basic Arduino Nano, but it didn’t have enough Flash memory available.
Then i wanted to use an STM32 L432KC nucelo32, but there are problems with communication with Arduino IDE. I am runnnig short on time to finish the project and i cant spend another week or two looking what the problem is.
That’s why i want to ask the community to help me pick one that is going to work well.
If you have experience with a microcontroller, and you already tested that it is going to work with Arduino IDE please give me a hint.
Take care everyone !
Hey,
In the Nano shape we would support, out of the box, also any of the newer Arduino Nanos, like the Nano 33 BLE, the Nano 33 IoT or the Nano 33 Sense.
We would also support the Nucleo 32 boards… while the STM32L series might give you some trouble, the STM32F4 or STM32G4 should be well supported.
Note also that with some effort we can probably get the L432 to work. It sounds like you were having problems with the flash memory size, which is usually something that can be fixed with options, or in the worst case by creating your own board description files…
A list of small boards I have personally tested and they work and will cover your use case:
Blue Pill
Black Pill
NUCLEO-G431KB
For the Nucleo-G431KB to make the 6pwm work you need to jump-solder one of the pin shunt leads (#8). If you do 3PWM no need to solder.
Problem with Blue Pill and Black Pill, is flashing with SWD debugger, if you don’t have one, just go for Nucleo-G431KB. Cheap and in stock.
What sensors do you need to use? Is your motor sensored? The only problem with that board is the limited number of pins, depending on your angle sensoring scheme.
@runger @Valentine Thank you so much for all your help
@Valentine The position feedback on the motor are Hall sensors, and i am planning to use in-line current sensing.
You will have enough free analog and IO pins for that.
When you get to that point if you decide to use the G431KB please come back here and ask, I will post the pin mappings that would work in your case. I was going to do this anyways because I’m in the process of mapping the G431KB board to make it work with the SimpleFOC Power Shield but I may speed it up if your needs are urgent.
Hey @Valentine thanks for the offer, i ordered the STM32G431KB T6U, so if you would like to help me with the pin mappings that would be great. I am planning to connect 6PWMbldc driver to 3 high/low N-mosfet drivers with hall sensors and 2 in-line curent sensors. If hardware interrupts possible then would be cool to use them. Thanks again!
This is the open loop code. I will post the analog current sense and hall sensors later, I’m traveling and will be back next week.
Below is the open loop code for testing. We have to re-write the code because I commented out a bunch of stuff you won’t need, but may need later. The way I posted it, it will work well for testing as is.
BLDCDriver6PWM driver = BLDCDriver6PWM(PA8, PA7, PA9, PB0, PA10, PF0, PA4);
//target variable
float target_velocity = 3.0;
float target_voltage = 3.0;
int analog_read_A0 = 0;
int analog_read_A1 = 0;
//Commander command = Commander(Serial);and.scalar(&target_velocity, cmd); }
//void doTarget(char* cmd) { comm
  //pinMode(PA15, OUTPUT);
  //digitalWrite(PA15, LOW);
  //driver.enable_active_high = false; // INFINEON ELICE DRIVER
  driver.pwm_frequency = 10000;
  // limiting motor movements
  motor.voltage_limit = 12;   // [V]
  motor.velocity_limit = 100; // [rad/s] cca 50rpm
  // open loop control config
  // init motor hardware
  //command.add('T', doTarget, "target velocity");
  //Serial.begin(115200);
  //Serial.println("Motor ready!");
  //Serial.println("Set target velocity [rad/s]");
  //analog_read_A0 = analogRead(PA3);
  //analog_read_A1 = analogRead(PA4);
  //target_velocity = float(map(analog_read_A0, 0, 4096, 0, 10000))/100.0;
  //target_voltage = float(map(analog_read_A1, 0, 4096, 0, 1200))/100.0;
  motor.voltage_limit = target_voltage;
  //command.run();
Hey @Valentine!
I was wondering if you might have some time to post the hall sensor - closed loop code and maybe also the current sensors code. I’ve got the open loop going and it works perfectly. The commander interface in open-loop also works the way it should.
I also tried to get the closed loop - velocity control going but there is a problem.
The code loads and everytghing seems to be ok, the driver.init(), sensor, motor.init(), FOC functions load correctly. Then when i try to use a commander command in the serial monitor/commander, it also seems to be working and the commander responds to setting target velocity in the serial monitor window.
The problem is, there is completely no PWM signal form the microcontroller no matter what the set target velocity is. I tried out multiple code configurations and nothing helps.
Also, when i add commander command for Full motor configuration:
command.add('M',onMotor,"full motor config");
the driver(), sensor() and rest of the functions stop loading and the code breaks, basically everything stops responding.
I tested the Hall sensors and they give out correct signals, and i have no further idea what the problem might be becouse the open loop works exactly the way it should.
Take care and thanks for all the help so far!
Could you post your code please? I haven’t tested this MCU with closed loop but I can try loading your code on mine and test.
The 4th iteration of the code :
// Hall sensor instance
// HallSensor(int hallA, int hallB , int hallC , int pp)
//  - hallA, hallB, hallC    - HallSensor A, B and C pins
//  - pp                     - pole pairs
HallSensor sensor =  HallSensor(PB7, PA15, PB6, 15);
BLDCDriver6PWM driver = BLDCDriver6PWM(PA8, PA7, PA10, PF0, PA9, PB0);
// channel A and B callbacks
void doA(){sensor.handleA();}
void doB(){sensor.handleB();}
void doC(){sensor.handleC();}
void onTarget(char* cmd) { command.target(&motor, cmd); }
void onMotor(char* cmd)  { command.motor(&motor, cmd); }
  // monitoring port
  // initialize sensor hardware
  // hardware interrupt enable
  driver.voltage_power_supply = 14;
  driver.pwm_frequency = 20000;
  Serial.print("Driver init ");// init driver
  if (driver.init())
  Serial.println("success!");
  else{Serial.println("failed!");
  return;}
  command.add('T', onTarget, "target velocity");
  //command.add('M', onMotor,  "motor");
  //command.motor(&motor,"E0");
float target_velocity = 0;
  // IMPORTANT - call as frequently as possible
  // update the sensor values
  sensor.update();
 //Serial.print(sensor.getAngle());
  //Serial.print("\t");
  //Serial.println(sensor.getVelocity());
I believe the problem is that you are accessing the default Serial. Please remove all references to serial and commander (comment them out) and try running a slow fixed speed. The default Serial conflicts with some of the other pins.
Hi @Valentine ,
I have this board and am finding the same as OP, I get no PWM out, even with your code above that comments out all serial.
I notice you did a solder bridge of SB8, what was that for, I havn’t done that …
Here is what I have for code …
// BLDCMotor motor = BLDCMotor(pole pair number, phase resistance (optional) );
//  BLDCDriver6PWM( int phA_h, int phA_l, int phB_h, int phB_l, int phC_h, int phC_l, int en)
//void onTarget(char* cmd) { command.target(&motor, cmd);}
//void onMotor(char* cmd)  { command.motor(&motor,cmd); }
  driver.voltage_power_supply =14;
  driver.pwm_frequency = 1000;
  //Serial.print("Driver init ");// init driver
  if (driver.init())
  //Serial.println("success!");
  //else{Serial.println("failed!");
  //return;}
  //motor.phase_resistance = 0.5; // [Ohm]
  //motor.current_limit = 3;   // [Amps] - if phase resistance defined
  motor.voltage_limit = 5;  // [V] - if phase resistance not defined
  motor.velocity_limit = 50;  // [rad/s] cca 50rpm
  //driver.dead_zone = 0.02;
  //command.add('T', onTarget, "target velocity");
  //command.add('M',onMotor,"full motor config");
  motor.move(0.01);
  //motor.move(5);
  //command.run();
The solder jumper is required to enable 6PWM on the timer attached to PA8, PA7, PA10, PF0, PA9, PB0.
Please read the documentation for that board.
Yep, tried that. No difference, no PWM on any pins…
I struggled to find the pin mapping for PWM in the documentation, can you please link the relevant section…
It’s just weird I get no PWM at all on this board, every other board I tried ESP32/RP2040/ATmega328 all work out of the box.
Ahh, do I need to bridge SB9,SB10 as well to use the 24Mhz xtal … will try.
EDIT: No difference … I wonder if this board is faulty… :cry:
Ahhhh … the issue was I had to put lib_archive = false in PlatformIO
If this constantly trips people up, can I recommend that it is placed by default in PlatformIO?
Where would you want us to set this as default? Not sure if we provide platformio files!
What we could do is put an obvious warning as Serial.println. e.g hardware detection failed, check lib_archive.
This trips up a lot if people
There is a recent PR to set the lib_archive by default: Add library.json to set libArchive #357 by runger1101001 · Pull Request #360 · simplefoc/Arduino-FOC · GitHub
It will be part of the next release, but unfortunately I think it might not be enough to fix the issue.
I agree that this issue is very annoying and causes a lot of problems for our users. I would love to find another solution. Perhaps it’s a point for the 2.5 release to move away from the weak bindings again.
