Hi all,
I’m very new to all of this, so was just wondering if anyone could let me know of any pitfalls with this approach.
This is the basic layout, but will have buttons on a switch, which i have left off for simplicity.
Firstly, I know this “works”. I have the basic setup on a breadboard, and it does work - but with a caveat…
On occasion, the motor will skip or get stuck in a short fast “forward and back” motion, as though it’s stuck between two magnets. However, I think think this is a bad connection on one of my buck converters, which I need to redo anyway. it’s either that, or a problem with the values in my code, or there’s a hardware issue i’m hoping someone can point out. Is there any specific drawback to this approach?
code and Pic below.
any feedback would be appreciated
// BLDCMotor(pole pair number, phase resistance (optional) );
// BLDCDriver3PWM(pwmA, pwmB, pwmC, Enable(optional));
driver.voltage_limit = 6;
if(!driver.init()){
return;
// limiting motor movements
motor.voltage_limit = 12; // [V]
// open loop control config
// init motor hardware
if(!motor.init()){
return;
// set the target velocity [rad/s]
//motor.target = 3.48; // 33.3RPM
motor.target = 4.71; // 45RPM
