BTN8962 for FOC Control - Arduino UNO
Hello everyone,
I recently started getting into SimpleFOC and i tried to replicate the PowerShield V2 on a breadboard with some BTN8962.
I have used this to wire the BTNs to the Arduino.
Here is the output of the BTNs that use that PWM:
The problem is that when I try to connect the motor to the setup it makes a buzzing sound and it moves a bit and stops.
The code that I used is for the open loop velocity control:
BLDCMotor motor = BLDCMotor(6);
//target variable
float target_velocity = 0;
driver.voltage_limit = 6;
if(!driver.init()){
Serial.println(“Driver init failed!”);
return;
// limiting motor movements
motor.voltage_limit = 2; // [V]
// open loop control config
// init motor hardware
if(!motor.init()){
Serial.println(“Motor init failed!”);
return;
Serial.println(“Motor ready!”);
Serial.println(“Set target velocity [rad/s]”);
// to turn the motor “backwards”, just set a negative target_velocity
Do you have any idea why this might be happening?
2
And this is the PWM generated by the Arduino
I’ve sucessfully used BTN7960 (ancestor of the BTN8962 available at Amazon) with simpleFOC and it worked decently. IIRC it was quite nonlinear WRT voltage at low speeds so make sure you’re trying a range of voltages but be really careful it’s easy to burn up a motor in openlooop mode. Some other questions:
-What model is your motor? Are you sure the poles are right?
-Have you checked all 3 motor phases? (you’re scope trace only shows 2 signals)
https://www.amazon.com/HUAREW-BTS7960-semiconductor-Refrigeration-Arduino/dp/B0CSFNNCQS/ref=sr_1_1_sspa?crid=30YPENCFGW6VS&dib=eyJ2IjoiMSJ9.mipk9AMYLEZI7DXMcE-gvGFZlnUxvrV6kQ2uqiwQjemzpGvbKWIyOWCnWxYP_b-umuxl7bn8hFzavjFLe8PUmKvXwNcaMXKOG721SU-JV-KaMbQkPClKciysenJbhQiw6I-RRjHOPfUBMYC1IaiCM-y7KrUbRG44mJbDfwE3Eho.PeZGyEUnrZlOp5kxP3yfQkKpk3hWugjbmehesnVmpd4&dib_tag=se&keywords=BTN7960&qid=1737784276&sprefix=btn7960%2Caps%2C97&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
i have 3 btn8962 with the output connected to each phase of a la8308 with 40p, it works fine in open loop, but in closed loop, with the as5600 magentic encoder it does not seem to work. The sensor works, i have tested it.
