I purchased a B-G431-ESC1 with an ex8101 105kv motor and a 600p/r rotary encoder.
I started loading the first code with simplefoc example for B-G431-ESC1
But I have a problem that I don’t understand, the motor initializes correctly but once I send the command to angle the motor runs for a few seconds and stops with the maximum amperage entered in the motor.current_limit
it is my last code, if i send velocity command (“M10”). motor begin turn and stop after few degres
* B-G431B-ESC1 position motion control example with encoder
// Motor instance
BLDCMotor motor = BLDCMotor(22, 0.186, 105);
// encoder instance
Encoder encoder = Encoder(A_HALL2, A_HALL1, 600);
// channel A and B callbacks
void doTarget(char* cmd) { command.motion(&motor, cmd); }
encoder.init();
motor.linkSensor(&encoder);
// current sensing
currentSense.init();
// no need for aligning
// aligning voltage [V]
// contoller configuration
motor.PID_velocity.P = 5;
motor.PID_velocity.I = 0;
motor.voltage_limit = 6;
motor.LPF_velocity.Tf = 0.01;
command.add('M', doTarget, "target");
//motor.monitor();
Have you moved ticked off all the simpler steps/modes before getting to this stage?
E.g
Sensor test (no driver)
Openloop velocity (no linked sensor)
Closed loop torque/voltage mode
I imagine you’ve done step 1 and 2, but have you done 3 (without any current sense code). That 3rd step requires no PIDs so is good closed loop ‘first test’.
I’m not great at current sense stuff but suspect torque mode = voltage isn’t using your current sensing (shouldn’t stop things working, just an observation)
If you have completed 3 then I’d probably move to something similar to what you have (closed loop velocity) but with no current sense. Then finally move back to something similar to your code base.
