Did any open source driver boards ever get braking resistors implemented?
I’d like to yoink a design to play around with.
I think your best chance is the older Odrive-clone from Ali (V3.6 IIRC?)
But other than having the FET and terminal for a resistor, you have to write your own code for that feature.
Any other board with a spare IO pin could use external FET switches for the same purpose.
