BLDC snaps to nearest pole
https://www.aliexpress.com/item/1005002058458786.html?spm=a2g2w.orderdetail.0.0.e0284aa6QiLV3g&sku_id=12000018589530076 I am running a 260kv motor with the simpleFOC mini, but whatever I try, the motor seems to “lock” to a pole, its stuck in one position and then I can physically push it to a next pole. Im sure that there is 7PP, but perhaps the phase resistance is wrong, Its not written anywhere. I am running using pico 2 and a usb c stepped up to 9v. The code is the edited example code to suit my pins and motor:
// BLDCMotor( pp number , phase resistance, KV rating)
BLDCMotor motor = BLDCMotor(7 , 12.5, 260);
BLDCDriver3PWM driver = BLDCDriver3PWM(0, 1, 2, 3);
void doLimitCurrent(char* cmd) { command.scalar(&motor.current_limit, cmd); }
  // limiting motor current (provided resistance)
  motor.current_limit = 0.5;   // [Amps]
  // open loop control config
  // init motor hardware
  command.add('C', doLimitCurrent, "current limit");
  // using motor.current_limit and motor.velocity_limit
