I have used the open loop example and the result after the motor init is some vibration from the motor, followed by a bit of smoke from a blown up controller.
Am i expecting too much from this controller , or we do need to setup something else?
If you are lucky, you may have blown just one of the channels. I’ve used this board but always use a bench power supply and limit voltage and current e.g 12v 1A. I reckon that would have saved your board from the magic smoke!
In software there are a couple of voltage_limits (one for normal use and one during initFOC) and depending on the resistance of your windings these might need to be set around 1v for bigger motors! Some V=IR maths will help make sure you don’t go much above 1A continuous.
Yeh, a bigger controller may be necessary to properly drive this motor!
