Beginner struggling to make motor rotate with ELEGOO Uno R3 and SimpleFOC Shield v3
Hello SimpleFOC Community,
First of all, thank you very much for developing and maintaining such a wonderful project.
I have been studying the SimpleFOC library source code and experimenting with it for about 20 days, but unfortunately I have not been able to get my motor to rotate correctly.
My setup is:
  • SimpleFOC Shield v3.2
  • Motor: ipower motor gm4108
I purchased the SimpleFOC Shield v3.2 from AliExpress because it was out of stock in the official store.
I am a beginner in electronics and motor control, so I honestly do not know whether the problem is caused by my code, wiring, hardware setup, or my misunderstanding of the library.
I would greatly appreciate any advice or guidance. If there is any information missing, please let me know and I will provide it immediately.
Thank you very much for your time and assistance.
The code is shown below:
BLDCDriver3PWM driver = BLDCDriver3PWM(6, 10, 5, 8);
float target_velocity = 2;
driver.voltage_limit = 6;
if(!driver.init()){
Serial.println(“Driver init failed!”);
return;
if(!motor.init()){
Serial.println(“Motor init failed!”);
return;
Serial.println(“Motor ready!”);
Serial.println(“Set target velocity [rad/s]”);
The serial monitor output is shown below:
MOT: Init
MOT: Enable driver.
Motor ready!
1 Answer
1
AFAIK you have to add motor.loopFOC(); in the main loop when you use the latest simpleFOC library
Maybe the example files aren’t up_to_date?
Thank you very much for your help. That was exactly the issue. I was using the latest SimpleFOC library, and the motor would not rotate with the original example code. I was using the Arduino IDE example: Examples -> Examples from Custom Libraries -> Simple FOC -> Motion Control -> Open Loop Motor Control -> open_loop_velocity_example (open_loop_velocity_example.ino) and it appears that motor.loopFOC(); was missing from that example. After adding motor.loopFOC(); to the main loop, the motor started rotating correctly. I truly appreciate your help and guidance. Thank you again fo
