Hello People,
I have a problem with my FOC current sense initialisation.
The setup:
I have a BLDC Motor called Ri50 from TMotor/CubeMars. It is in a 3D Printed case and has the AS5048B (I2C) chip as a rotary encoder. This I2C connection works as far as I know flawlessly and gives good position data.
The code: (mostly copied from the examples/hardware_specific_exaples/B_G431B_ESC1.ino)
BLDCMotor motor = BLDCMotor(7, 1.42, 96); // pole pair, phase resistance (optional), KV (optional)
BLDCDriver6PWM driver = BLDCDriver6PWM(PA8, PC13, PA9, PA12, PA10, PB15);
MagneticSensorI2C sensor = MagneticSensorI2C(AS5048_I2C);
void doTarget(char* cmd) { command.motion(&motor, cmd); }
// init sensor
// link sensor to motor
// init driver
// link driver to motor
// aligning voltage [V]
// contoller configuration
motor.PID_velocity.P = 0.2;
motor.PID_velocity.I = 20;
motor.voltage_limit = 24;
motor.LPF_velocity.Tf = 0.01;
// angle P controller
motor.P_angle.P = 20;
motor.velocity_limit = 4;
delay(1000);
After a small hiccup with the “-DHAL_OPAMP_MODULE_ENABLED” flag this compiles without a problem and gives following data via USB Serial connection:
MOT: sensor_direction==CW
MOT: PP check: OK!
MOT: Zero elec. angle: 4.09
MOT: Init FOC error, current sense not initialized
MOT: Init FOC failed.
Motor ready.
0.0000 0.0000 0.0728 3.2984
0.0000 0.0000 -0.1169 3.2965
0.0000 0.0000 0.0168 3.2977
0.0000 0.0000 0.0466 3.2981
0.0000 0.0000 -0.0009 3.2977
0.0000 0.0000 0.0853 3.2984
0.0000 0.0000 0.0690 3.2984
0.0000 0.0000 0.0431 3.2981
0.0000 0.0000 0.0490 3.2981
0.0000 0.0000 0.0341 3.2981
0.0000 0.0000 0.0346 3.2981
0.0000 0.0000 0.0719 3.2984
As you can see everything seems to work except the current sense initialisation.
Do you have any Idea why this would not work ? Did I miss something or is my Code wrong ?
I would appreciate your input and hope you have a nice day
