B-G431B-ESC1: Motor Not Spinning in Closed-Loop Mode
Hello everyone!
I need some assistance with running my BLDC motor in closed-loop mode. Here’s the configuration of the hardware I’m using:
  • Driver: B-G431B-ESC1
  • Motor: Tarot gopro brushless motor (12N14P)
  • Encoder: AS5047U in encoder mode
  • Power Supply: 12V
I’ve tested the encoder separately, and it works correctly, giving a value of 6.28 radians per full rotation. I also tested the motor in open-loop mode, and it runs smoothly, maintaining the set speed. I verified the encoder signal using a logic analyzer, and the encoder provides exactly 1000 pulses per revolution, without any noise.
The issue arises when I try to run the motor in closed-loop mode. Here’s what happens:
During the index search, the motor spins smoothly and correctly finds the zero position. However, after that, the motor refuses to rotate. I tried increasing the target using the M command, and while the current draw increases, the motor doesn’t move at all. In the console, I receive the following output:
Console output
TIM1-CH1 TIM1-CH1N TIM1-CH2 TIM1-CH2N TIM1-CH3 TIM1-CH3N score: 1
STM32-DRV: best: TIM1-CH1 TIM1-CH1N TIM1-CH2 TIM1-CH2N TIM1-CH3 TIM1-CH3N score: 1
STM32-DRV: Syncronising timers! Timer no. 1
STM32-DRV: Restarting timer 1
MOT: Monitor enabled!
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: Index search...
MOT: Success!
MOT: sensor_direction==CCW
MOT: PP check: fail - estimated pp: 8.66
MOT: Zero elec. angle: 0.29
MOT: No current sense.
MOT: Ready.
Motor ready.
Set the target using serial terminal and command M:
PlatformIO configuration
[env:disco_b_g431b_esc2]
platform = ststm32
board = disco_b_g431b_esc1
framework = arduino
upload_protocol = stlink
monitor_speed = 115200
lib_archive = false
build_flags = -DHAL_OPAMP_MODULE_ENABLED
lib_deps =
  askuric/Simple FOC@^2.3.4
  SPI
  Wire
Source code
// BLDCMotor(pole pair number, phase resistance (optional) );
// BLDCDriver6PWM(pwmAh, pwmAl, pwmBh, pwmBl, pwmCh, pwmCl, (en optional))
Encoder encoder = Encoder(A_HALL1, A_HALL2, 1000, A_HALL3);
// interrupt routine initialisation
void doIndex(){encoder.handleIndex();}
encoder.init();
encoder.enableInterrupts(doA, doB, doIndex);
motor.linkSensor(&encoder);
// driver init
if(!driver.init()){
  return;
// link driver
// aligning voltage
// motor.sensor_direction = Direction::CW;
if(!motor.init()){
  return;
// align sensor and start FOC
if(!motor.initFOC()){
  Serial.println("FOC init failed!");
  return;
// set the initial motor target
motor.target = 2; // Volts
// add target command M
command.add('M', doMotor, "Motor");
Serial.println(F("Set the target using serial terminal and command M:"));
Has anyone experienced a similar issue or have any ideas on how to resolve this?
Thank you in advance for your help!
Is this correct?
Nevermind it’s correct if it’s encA, encB, ppr, index pin
I also tried connecting the current sensor as shown in the example. The motor started spinning, but the current sensor readings seem too noisy. The motor runs in torque mode, but its behavior in other modes is very unstable. Here is the code for the sensor initialization:
I had to raise the LPF value to 0.05, as the readings were too noisy before. It also seems strange to me that the current sensor shows approximately 240 mA, while the measured value with an ammeter is 330 mA. The set target is 1A, but changing this value does not affect the actual current consumption.
Hi @Stinger , welcome to SimpleFOC.
I think the PP check should not be failing on a 7PP motor with encoder.
You can try changing the alignment voltage a bit to see if you can improve the result…
