B-G431-ESC1 SimpleFOC Studio
Hi Sir,
This is related to this one.
I am trying to use simpleFoC Studio to fine tune PID parameter.
While, the SimpleFoC studio GUI did not reflash data.
I can manually send commands through GUI to B-G431-ESC1 board to control BLDC motor, but the GUI cannot receive correct data, showing unknow cmd err.
My code shows as below.
  • B-G431B-ESC1 position motion control example with encoder
#include<Arduino.h>
// Motor instance
// encoder instance
Encoder encoder = Encoder(A_ENCODER_A, A_ENCODER_B, 1000);
// channel A and B callbacks
void doC(){encoder.handleIndex();}
void doTarget(char* cmd) { command.motion(&motor, cmd); }
void doMotor(char* cmd) { command.motor(&motor,cmd);}
encoder.init();
motor.linkSensor(&encoder);
// current sensing
currentSense.init();
// no need for aligning
// currentSense.skip_align = true;
// motor.velocity_index_search = 3;
// aligning voltage [V]
motor.voltage_sensor_align = 1.2;
// if you are not using aligning voltage, you can set current limitation
motor.phase_resistance = 0.4; // [Ohm]
motor.current_limit = 3; // [Amps] - if phase res is defined
// contoller configuration
motor.PID_velocity.P = 0.04;
motor.PID_velocity.I = 2.1;
motor.voltage_limit = 1;
motor.LPF_velocity.Tf = 0.01;
// angle P controller
motor.P_angle.P = 17.2;
//motor.P_angle.I = 0.07;
motor.P_angle.D =0.005;
motor.velocity_limit = 15;
// foc currnet control parameters (stm/esp/due/teensy)
//motor.PID_current_q.P = 5;
//motor.PID_current_q.I= 1000;
//motor.PID_current_d.P= 5;
//motor.PID_current_d.I = 1000;
//motor.LPF_current_q.Tf = 0.002f; // 1ms default
//motor.LPF_current_d.Tf = 0.002f; // 1ms default
motor.monitor_downsample = 100; // setting sample rate, can up to 100+
// motor.monitor_variables = _MON_TARGET | _MON_CURR_Q | _MON_CURR_D | _MON_VEL | _MON_ANGLE;
motor.target = 30;
// command.add(‘T’, doTarget, “target angle”);
command.add(‘M’, doMotor, “motor”);
// command.add(‘A’,doMotor,“my motor”);
// Serial.println(F(“Motor ready.”));
// Serial.println(F(“Set the target angle using serial terminal:”));
// Debug encoder, done, everything is correct
// not doing much for the encoder though
// encoder.update();
// Serial.print(encoder.getAngle());
// Serial.print(“\t”);
// Serial.println(encoder.getVelocity());
// driver.setPwm(0.3,0.6,0.5);
Hi @kuqn ,
In the code you use letter “M” for the doMotor() so you have to enter this letter into the box labeled “Command” in SimpleFOCStudio. Then it should work! :slight_smile:
