B-G431-ESC1 Does not spin even in Open-Loop
Hi, I hope everyone is fine. I’m trying to spin my X2216-5 2400KV motor with B-G431-ESC1, however the results are always the same. I have 3 boards, i have tried to spin my motor in every board, but result did not change. I’m using PlatformIO on VsCode. You can acces the files such as specs of my motor, digital oscilloscope image with the provided code and the code that i was trying to use, in the down below. Please help me about it, because I’m going to lose my mind over it. Once I’ve accomplished my goal “Spinning the motor via this esc”, i want to use AS5600 sensor for precision. After that i will try to make a custom pcb with this mcu or something else.
The code is nearly the copy of open_loop_velocity_example which is provided as an example.
BLDCMotor motor = BLDCMotor(5, .029, 2400);
// target variable
float target_velocity = 0;
void doTarget(char* cmd) {
    float prev_target = target_velocity;
    command.scalar(&target_velocity, cmd);
    Serial.print("Target velocity changed from ");
    Serial.print(prev_target);
    Serial.print(" to ");
    Serial.print(target_velocity);
    Serial.println(" rad/s");
void doLimit(char* cmd) {
    float prev_limit = motor.voltage_limit;
    command.scalar(&motor.voltage_limit, cmd);
    Serial.print("Voltage limit changed from ");
    Serial.print(prev_limit);
    Serial.print(motor.voltage_limit);
    Serial.println(" V");
  driver.voltage_limit = 6;
  if(!driver.init()){
    return;
  // limiting motor movements
  motor.voltage_limit = 1.2;   // [V]
  // open loop control config
  // init motor hardware
  if(!motor.init()){
    return;
  // using motor.voltage_limit and set target_velocity
platformio.ini file:
;   Build options: build flags, source filter
;   Upload options: custom upload port, speed and extra flags
[env:disco_b_g431b_esc1]
board_build.f_cpu = 170000000L
platform = ststm32
board = disco_b_g431b_esc1
framework = arduino
monitor_speed = 115200
build_flags =
    -DCONFIG_DISABLE_DEBUG
    -D USBCON
    -D HAL_OPAMP_MODULE_ENABLED
    -I driver
lib_archive = false
lib_deps =
    https://github.com/simplefoc/Arduino-FOC
Motor Specs and the image of Motor:
I will be providing the image of the phases with my oscilloscope, if wanted.
Please help me about this situation.
1 Answer
1
Hi, did you try setting target velocity to some other initial value then 0.0? Your issue might be with the Commander and serial communication – perhaps target_velocity never gets set to a non zero value.
Even at target velocity 0, you should be able to feel that motor resists turning when the power is on. If not, then there may be something wrong with your board or connections.
I basically tried the same thing yesterday (different motor though). Only difference I can see is not using Commander and using Serial2 instead of Serial and using a somewhat different platformio.ini:
platform = ststm32
framework = arduino
lib_archive = false
build_flags =
 ;   -D PIO_FRAMEWORK_ARDUINO_USB_HIGHSPEED_FULLMODE
lib_deps=
    askuric/Simple FOC @ ^2.0.2
    SPI
    Wire
Note the ENABLE_CDC which enables serial communication via USB and the embedded STLINK v.2 AFAIK. And note that I had to comment out the request for for USB highspeed (relative to the instructions on B-G431B-ESC1: Beginner guide + I2C guide).
