AS5600 sensor analog output problem in distance
Assalamualaikum, I’m using AS5600 Magnetic Encoder Sensor for one of my project. When I setup magnet distance 1 mm in between magnet and AS5600, I got both I2C and analog signal smoothly. But when the distance is 3mm or more I got only I2C value correctly and did not get any analog signal. I study the datasheet and I did not found any logical cause.
I’m using 3.3v in whole system, battery powered. And using the module board so that did not add additional capacitor.
I need the analog signal in between 3 to 5 mm distance. Please suggest a guideline to get the data.
Thank you.
I’ve tried in several distance. Only 1 mm distance provide analog signal. my expecting is to get signal from the sensor from 5 mm distance.
Why are you opening a new thread for the same question ?
https://community.simplefoc.com/t/assalamualaikum-im-using-as5600-magnetic-encoder-sensor-for-one-of-my-project-when-i-setup-magnet-distance-1-mm-in-between-magnet-and-as5600-i-got-both-i2c-and-analog-signal-smoothly-but-when-the-distance-is-3mm-or-more-i-got-only-i2c-value-correctly/4586/2?u=runger
I think that was partly the forum software fault, one of his posts needed to be approved (sometimes happens to new user) so got delayed a day. I imagine he reposted when it didn’t show
