Hi guys, I’m now trying to run a gimbal motor with as5600 and mega2560 for my project. My problem now is that the motor is spinning during the init process but the serial shows that this process failed because no movement was detected from the sensor. I’ve also checked the sensor with the magnet sensor iic test example in the utils and it works fine.
These are the messages I got from the serial:
MOT: Monitor enabled!
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: Init FOC failed.
and here is my program:
MagneticSensorAnalog sensor1 = MagneticSensorAnalog(A1, 0, 1023);
BLDCMotor motor1 = BLDCMotor(7);
BLDCDriver3PWM driver1 = BLDCDriver3PWM(11, 10, 9, 8);
float target_angle = 4;
// commander interface
void doTarget(char* cmd) {
command.scalar(&target_angle, cmd);
void setup()
sensor1.init();
motor1.linkSensor(&sensor1);
driver1.voltage_power_supply = 24;
driver1.init();
// link driver
motor1.linkDriver(&driver1);
// control loop type and torque mode
motor1.torque_controller = TorqueControlType::voltage;
motor1.controller = MotionControlType::angle;
motor1.motion_downsample = 10.0;
// velocity loop PID
motor1.PID_velocity.P = 0.4;
motor1.PID_velocity.I = 0.0;
motor1.PID_velocity.D = 0.0;
motor1.PID_velocity.output_ramp = 0.0;
motor1.PID_velocity.limit = 12.0;
motor1.LPF_velocity.Tf = 0.01;
// angle loop PID
motor1.P_angle.P = 29.0;
motor1.P_angle.I = 0.2;
motor1.P_angle.D = 0.0;
motor1.P_angle.output_ramp = 0.0;
motor1.P_angle.limit = 100.0;
motor1.LPF_angle.Tf = 0.02;
// Limits
motor1.velocity_limit = 25.0;
motor1.voltage_limit = 20.0;
motor1.current_limit = 5.0;
// monitoring port
motor1.useMonitoring(Serial);
// initialise motor
motor1.init();
// align encoder and start FOC 1.14, Direction::CCW
motor1.initFOC();
motor1.loopFOC();
//Serial.println(sensor1.getAngle());
motor1.move(target_angle);
