AS5600 "dead spot" around 0
I have slightly modified the example code for ESP32 + I2C magnetic sensor to allow motor commands as suggested by @Antun_Skuric.
here is the code (just for tracability, nothing special)
   ESP32 position motion control example with magnetic sensor
// SPI Magnetic sensor instance (AS5047U example)
// MISO 12
// MOSI 9
// SCK 14
//MagneticSensorSPI sensor = MagneticSensorSPI(10, 14, 0x3FFF);
// I2C Magnetic sensor instance (AS5600 example)
// make sure to use the pull-ups!!
// SDA 21
// SCL 22
//MagneticSensorI2C(chip_address,bit_resolution, angle_register_msb, bits_used_msb)
// Analog output Magnetic sensor instance (AS5600)
// Motor instance
//  BLDCMotor( pin_pwmA, pin_pwmB, pin_pwmC, pole_pairs, enable (optional))
BLDCMotor motor = BLDCMotor(25, 26, 27, 14);
  // power supply voltage
  // default 12V
  motor.voltage_power_supply = 12;
  motor.controller = ControlType::angle;
  // contoller configuration
  motor.PID_velocity.P = 0.5;
  motor.PID_velocity.I = 20;
  motor.voltage_limit = 6;
  motor.LPF_velocity.Tf = 0.01;
  // angle P controller
  motor.P_angle.P = 1;
  motor.velocity_limit = 30;
  // align sensor and start FOC
  Serial.println("Set the target angle using serial terminal:");
// angle set point variable
float target_angle = 0;
  // Arduino UNO loop  ~1kHz
  // Bluepill loop ~10kHz
  // motor.move(target_angle);
  // motor.monitor();
  //  // user communication
  //serialReceiveUserCommand();
  motor.command(serialReceiveUserCommand());
//void serialReceiveUserCommand() {
//  // a string to hold incoming data
//  static String received_chars;
//  while (Serial.available()) {
//    // get the new byte:
//    char inChar = (char)Serial.read();
//    // add it to the string buffer:
//    received_chars += inChar;
//    // end of user input
//    if (inChar == '\n') {
//      // change the motor target
//      target_angle = received_chars.toFloat();
//      Serial.print("Target angle: ");
//      Serial.println(target_angle);
//      // reset the command buffer
//      received_chars = "";
// utility function enabling serial communication the user
String serialReceiveUserCommand() {
  String command = "";
      // execute the user command
      command = received_chars;
  return command;
I have noticed a strange behavior (or side effect ?) (or still a bug on my side ?) that I would like to share with you.
When the target position is set to 0, then I can feel a dead zone (very small) where the motor seems to be unpowered. I can’t feel force feedback and even hear a small “clac” as if it was a mechanical backlash.
If I set target at 0.1 (or any other value) then this “backlash” disappears and the force feedback is immediatly present.
Any idea please ? Is it something that you already noticed or am I alone with this “dead spot” ?
Thanks in advance
JP
Hi @freedom2000,
I had the same problem with the “dead spot” and I think I could solve it.
In “MagneticSensorI2C.cpp” the angle is read from adress 0x0E. That is an angle which contains a hysteresis.
I changed the adress to 0x0C to read the raw angle and it seems to work fine.
This looks fine :slight_smile:
I thought I was alone to get this behavior !
@Uli you just saved me a batch of AS5600 I was about to throw away. Thanks for an excellent workaround.
I’m thinking, if all of the AS5600 suffer from this dead spot jerk, it would warrant a pull request to the library.
Absolutely right, its going to be integrated into the new release!
