AS5048B Magnetic Encoder with SimpleFOC board for Position Control
We are using following components for building the Position control of BLDC Motor
  1. SimpleFOC board received last week
  2. iPower GM2804 BLDC Motor
  3. AS5048B Magnetic Encoder
The magnetic encoder is connected through I2C ports and modified the file angle_control file to establish I2C communication, Pole pairs, bit resolution, Memory map.
//MagneticSensorSPI sensor = MagneticSensorSPI(10, 14, 0x3FFF);
MagneticSensorI2C sensor = MagneticSensorI2C(0x40, 14, 0xFE, 8);
// BLDC motor instance
BLDCMotor motor = BLDCMotor(9, 10, 6, 7, 8);
// Stepper motor instance
//StepperMotor motor = StepperMotor(9, 5, 10, 6, 50, 8);
  // power supply voltage
  // default 12V
  motor.voltage_power_supply = 12;
  motor.controller = ControlType::angle;
  // contoller configuration
  motor.PID_velocity.P = 0.2;
  motor.PID_velocity.I = 20;
  motor.voltage_limit = 6;
  motor.LPF_velocity.Tf = 0.01;
  // angle P controller
  motor.P_angle.P = 20;
  motor.velocity_limit = 20;
  // align sensor and start FOC
  Serial.println("Set the target angle using serial terminal:");
// angle set point variable
float target_angle = 0;
  // Arduino UNO loop  ~1kHz
  // Bluepill loop ~10kHz
  motor.move(target_angle);
  // motor.monitor();
  serialReceiveUserCommand();
When we provide angle command(in degree) through serial command, it just rotate continuously with vibration. Please provide the solution for this.
Hi, I haven’t completely checked your code, but by default angles are in radians in the SimpleFOC environment. So I would give that a go first.
About the vibrations: this could be caused by controller parameters that are not optimal for your setup. It could also be this issue: https://community.simplefoc.com/t/simplefocshield-routing-mistake-v1-3-3-version-11-2020/333?u=jornel.
Try:
motor.PID_velocity.I = 5;
motor.voltage_limit = 4;
You could try commenting out all of the PID and LPF code for now. I got a similar motor working out of the box in angle mode with the default SimpleFOC PID params. When I put in some of the PID params from the example code I had issues.
Also, from my post the other day, make sure your encoder hub/magnet is correctly mounted to your motor (without slipping etc) or else SimpleFOC will get confused - In my case this manifested as constant spinning.
@akashlpatil were you able to resolve your problem.
Please make sure to start with the open loop example, then the voltage control and save the angle control for the last. :smiley:
@Antun_Skuric: Yes it is working after making these changes https://community.simplefoc.com/t/simplefocshield-routing-mistake-v1-3-3-version-11-2020/333
Need to tune the PID values for removing low frequency vibration.
