In case anyone comes up across the same problem: I have managed to code a Stepper Driver Class for the Adafruit Motorshield V2 using some basic Methods of the Adafruit_MotorShield library.
Ino-File:
#include "StepperDriverAdafruitMotorshieldV2.h"
//Adafruit Motorshield Port M3 & M4
#define PWMA 2
#define AIN2 3
#define AIN1 4
#define PWMB 7
#define BIN2 6
#define BIN1 5
int in1[] = {AIN1,AIN2};
int in2[] = {BIN1,BIN2};
StepperDriverAdafruitMotorshieldV2 driver=StepperDriverAdafruitMotorshieldV2(PWMA, in1, PWMB,in2);
driver.pwm_frequency = 1000;
driver.voltage_power_supply = 11;
driver.voltage_limit = 11;
// driver init
// enable driver
driver.enable();
driver.setPwm(6,3);
StepperDriverAdafruitMotorshieldV2.cpp
StepperDriverAdafruitMotorshieldV2::StepperDriverAdafruitMotorshieldV2(int _pwm1, int* _in1, int _pwm2, int* _in2, int en1, int en2){
// Pin initialization
pwm1 = _pwm1; // phase 1 pwm pin number
dir1a = _in1[0]; // phase 1 INA pin number
dir1b = _in1[1]; // phase 1 INB pin number
pwm2 = _pwm2; // phase 2 pwm pin number
dir2a = _in2[0]; // phase 2 INA pin number
dir2b = _in2[1]; // phase 2 INB pin number
// enable_pin pin
enable_pin1 = en1;
enable_pin2 = en2;
// default power-supply value
voltage_power_supply = DEF_POWER_SUPPLY;
voltage_limit = NOT_SET;
pwm_frequency = NOT_SET;
AFMS = Adafruit_MotorShield();
// enable motor driver
void StepperDriverAdafruitMotorshieldV2::enable(){
// enable_pin the driver - if enable_pin pin available
if ( _isset(enable_pin1) ) digitalWrite(enable_pin1, HIGH);
if ( _isset(enable_pin2) ) digitalWrite(enable_pin2, HIGH);
// set zero to PWM
setPwm(0,0);
// disable motor driver
void StepperDriverAdafruitMotorshieldV2::disable()
// set zero to PWM
setPwm(0, 0);
// disable the driver - if enable_pin pin available
if ( _isset(enable_pin1) ) digitalWrite(enable_pin1, LOW);
if ( _isset(enable_pin2) ) digitalWrite(enable_pin2, LOW);
// init hardware pins
int StepperDriverAdafruitMotorshieldV2::init() {
AFMS.begin(pwm_frequency);
return 0;
// Set voltage to the pwm pin
void StepperDriverAdafruitMotorshieldV2::setPwm(float Ua, float Ub) {
float duty_cycle1(0.0f),duty_cycle2(0.0f);
// limit the voltage in driver
Ua = _constrain(Ua, -voltage_limit, voltage_limit);
Ub = _constrain(Ub, -voltage_limit, voltage_limit);
// hardware specific writing
duty_cycle1 = _constrain(abs(Ua)/voltage_power_supply,0.0f,1.0f);
duty_cycle2 = _constrain(abs(Ub)/voltage_power_supply,0.0f,1.0f);
AFMS.setPWM(pwm1,duty_cycle1*4095);
if (Ua>0) {
AFMS.setPin(dir1a,LOW);
AFMS.setPin(dir1b,HIGH);
} else {
AFMS.setPin(dir1a,HIGH);
AFMS.setPin(dir1b,LOW);
AFMS.setPWM(pwm2,duty_cycle2*4095);
if (Ub>0) {
AFMS.setPin(dir2a,LOW);
AFMS.setPin(dir2b,HIGH);
} else {
AFMS.setPin(dir2a,HIGH);
AFMS.setPin(dir2b,LOW);
#ifndef STEPPER_DRIVER_ADAMOTOV2_h
#define STEPPER_DRIVER_ADAMOTOV2_h
#include <Adafruit_MotorShield.h>
class StepperDriverAdafruitMotorshieldV2: public StepperDriver
public:
StepperDriverAdafruitMotorshieldV2(int pwm1, int* in1, int pwm2, int* in2, int en1 = NOT_SET, int en2 = NOT_SET);
/** Motor hardware init function */
int init() override;
/** Motor disable function */
void disable() override;
/** Motor enable function */
void enable() override;
// hardware variables
int pwm1; //!< phase 1 pwm pin number
int dir1a; //!< phase 1 INA pin number
int dir1b; //!< phase 1 INB pin number
int pwm2; //!< phase 2 pwm pin number
int dir2a; //!< phase 2 INA pin number
int dir2b; //!< phase 2 INB pin number
int enable_pin1; //!< enable pin number phase 1
int enable_pin2; //!< enable pin number phase 2
// Adafruit Motorshield object
Adafruit_MotorShield AFMS;
* Set phase voltages to the harware
* @param Ua phase A voltage
* @param Ub phase B voltage
void setPwm(float Ua, float Ub) override;
private:
#endif
