Hey y’all!, I apologize if this has been answered already, but I haven’t had any luck yet. Are there any existing Arduino libraries for sending commands and receiving telemetry over uart on another Arduino not running SimpleFOC?
I have 4 motors running on different v-g431b-esc1s and I’d like to have a central Teensy4.1 synchronizing operation of these 4 motors by receiving telemetry and sending commands to each, doing some control, and forwarding telemetry/commands to/from a host PC. I saw the PacketCommaner, Command, and Telemetry classes, but those look like they’re only meant to handle the SimpleFOC side of things, and I saw the pysimplefoc, but I’d like to run this on an MCU so I can have solid timing control. Any guidance would be appreciated, thanks!
Have you considered utilizing a CAN Bus to facilitate communication among all your motors? With just a pair of cables, you can seamlessly connect as many MCUs as needed.
Yeah, it seems like it could be a good long term solution, but I’m worried I’ll be in the same position of writing a custom handler and having to deal with the increased complexity of CAN on top of that.
Yes, you’re right… using a CAN bus introduces a bit of complexity, but from my point of view, if you want and can afford to take on the additional cost, it’s a very profitable investment in the medium and long term.
If you work with STM32 or ESP32 thaen you can give a try to SimpleCAN from @Owen_Williams . It is a generic library but can be easily used to do what you want without having to deal with low level details.
