A2212/13t BLDC motor and problems
I’m wondering whether you are using an old version of the code. Older versions don’t have sensor.getAngle() in it.
  while(motor_angle <= pp_search_angle){
    motor_angle += 0.01;
    sensor.getAngle(); // keep track of the overflow
    motor.setPhaseVoltage(pp_search_voltage, motor_angle);
It might be useful to print out that angle in the while loop to see what its up to.
Yeah, i inverted motor wires. But it still make some small angle while i run find_pole_pairs code. So i basically can write 6.28 in code and motor should turn for 360 degrees. Instead of that it goes a little bit forward and then back to start position. If i put 12.6, motor just do it two times.
I use Arduino uno with mega328p chip
Its 1.4.1 version installed with library manager in Arduino ide
I use 8,9,10 pins for A,B,C pwm and 8 for enable. I checked it many times.
  1. Yeah, i tried. But it didnt help.
  2. This is small because motor itself moving on a very small angle. I’ve checked again. Its as5047d encoder with 14 bit.
I use code with sensor.getAngle() in it.
Can I summarise where you are at.
  • You can run open loop code. The motor spins forwards and backwards (depending on +-=0.001)
  • you can manually spin the motor a whole turn and it correctly says 6.3 rads when you ask what the angle is
  • when you run find_pole_pairs it barely moves and/or moves erratically left to right
This is odd as pole_pairs is more or less the same as open loop.
Can you check that your
BLDCMotor motor = BLDCMotor(9, 5, 6, 0, 8); is the same between pole_pairs and open loop.
@Antun_Skuric asked about which pins you use. I guess you are using 9,5,6,8 for motor and 10 for chip select for SPI. SPI will also be using 3 other pins (11, 12 and 13 is common for Uno I think). Uno is also using 0 and 1 for serial port. Does that sound right?
I’d get a fresh copy of pole_pairs especially if you’ve made changes e.g. to pp_search_angle
Oh shit, man. You’ve just opened my eyes!
I solved this problem. This happened only because im completely bad at coding and even didnt analyze it.
So imagine my situation:
Im a complete noob at coding and i tried to use step by step information from @Antun_Skuric video and from documentation. So when i was soldering this pcb, i didnt know which pins i should solder. So i just opened the video and there were following pins:
So i soldered them as it was shown in the video.
Ok, the next step was to connect my magnetic sensor, right? Im opened the documentation and saw the next picture:
So i just connected everything as it is shown in the picture.
Then I tried to use the code examples. So I had next motor configuration: BLDCMotor motor = BLDCMotor(9, 10, 11, 14(number of poles), 8);
And at that time I didnt even realise that I had to change my pins in:
It is due to the fact that I connected the sensor by tutorial and i thought that everything would be alright.
And after all these steps I got my problem. And the problem was: the motor uses 9,10 and 11 pins, and at the same time the magnetic sensor uses 10,11,12 and 13 pins.
I just changed the soldered pins on my pcb and changed them in the code. And it is working now!
Thanks everyone for helping me here!
Glad to hear you got there! Now you can have some fun getting the PI tuning sorted. That’ll be a few more hours head scratching!
I find a combination of calling motor.monitor() in the main loop() and viewing the output in a serial plotter invaluable. You’ll be able to see how the velocity wobbles and settles as you change your PI and Tf tunings. Don’t try angle control mode until velocity control mode is stable. Angle control mode requires you to have a nicely tuned velocity PI and Tf values.
