24n22p gimbal motor winding configuration
Hi, one of my 24n22p gimbal motor got broken and now I’m trying to wind it all over again.
Initially the motor’s winding is AaAabBbBCcCcaAaABbBbcCcC, but I came across the following image.
ref: https://www.x-teamrc.com/x-team-bldc-motors-stator-and-rotor-design-for-brushless-motors/
I assume this winding is AabBCcaABbcCAabBCcaABbcC and here is the result of winding scheme calculator.
It says the winding factor is 0, so maybe I shouldn’t try this, but just out of curiosity I wanted to know if this works with simplefoc library.
Here is the motor spces:
GBM5208-75T 24n22p 15.0Ω
0.22mm wire
There’s not much to be gained since the regular scheme has such a high winding factor already, but you could always do a test wind to see if it will run. Use fine wire and maybe 3 turns per tooth so it doesn’t take long or waste much, and test with a drone ESC. If it runs, you can redo it with large number of turns for your SimpleFOC setup, or go back to the original scheme.
I was always confused about these 24n22p motors.
In my book 24n20p would make more sense?!
Just check out the red coil: 1/2 and 13/14 are aligned nicely, but the other two pairs are way off.
That might be a trick to reduce cogging, but it’s a huge waste of energy, right?
