I have started doing a battery pack design.
Somehow all the opensource BMS circuits are using resistors to burn energy for balancing (passive balancing). Active Balancing transports energy from the strongest battery to the weakest, thereby increasing the overall range, since the weakest battery determines when the entire pack is done.
The idea is to do a integrated PCB design, which uses 3mm diameter copper pipes, to connect the top side with the bottom side PCB. With the large width of the trances between cell´s, the copper can be kept relatively thin, lowering cost and resistance.
If you know about a opensource Active Balancing project, plz let us know. All ideas are welcome !
Edit: 28-04-2022 The circuit design has taken several turns since the initial idea. Active Balancing is given up, since it simply is not worth doing for a “small” 14S4P battery. A passive balancing approach with top balancing is more then fine. There are many factors involves when it comes to how often the BMS will balance the sell´s, especially if the cells are of different age and use could there arise some imbalance.
