I have this problem, i have a gimbal motor and AMT103 Encoder. I used the code of the site but when I start program the motor go crazy, I can’t controll it and controll the right angle that I want.
This is the code:
// software interrupt library
#include <PciManager.h>
#include <PciListenerImp.h>
// encoder instance
Encoder encoder = Encoder(2, 3, 8192, A0);
// channel A and B callbacks
void doIndex(){encoder.handleIndex();}
PciListenerImp listenerIndex(encoder.index_pin, doIndex);
// angle set point variable
float target_angle = 0;
encoder.init();
// software interrupts
PciManager.registerListener(&listenerIndex);
motor.linkSensor(&encoder);
// aligning voltage [V]
// contoller configuration
motor.PID_velocity.P = 0.2;
motor.PID_velocity.I = 20;
motor.voltage_limit = 6;
motor.LPF_velocity.Tf = 0.01;
// angle P controller
motor.P_angle.P = 20;
motor.velocity_limit = 4;
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
motor.move(target_angle);
// motor.monitor();
This is the Serial Comunication:
MOT: Monitor enabled!
MOT: Init
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: sensor_direction==CCW
MOT: PP check: fail - estimated pp:141.8528
MOT: Zero elec. angle: 0.88
MOT: No current sense.
MOT: Ready.
Motor ready.
