hello,
i working on Encoder, velocity controll loop in closed loop. it working absolutly fine between range 0-90 on 12V, aslo there is good torque. but when i operate it on 24v there in no torque after 20velocity . if u touch motor by hand its current increse to 10amp. so any suggestion of your will be my time savier. code is here
BLDCMotor motor = BLDCMotor(2);
BLDCDriver3PWM driver = BLDCDriver3PWM(25, 26, 27, 32);
// encoder instance
Encoder encoder = Encoder(15, 4, 1024 );
// channel A and B callbacks
float target_velocity = 1.2;
encoder.init();
motor.linkSensor(&encoder);
// aligning voltage [V]
// contoller configuration
motor.PID_velocity.P = 0.015f;
motor.PID_velocity.I = 0.5;
motor.voltage_limit = 15;
// align sensor and start FOC
Serial.println(F(“Set the target velocity using serial terminal:”));
void loop()
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
// motor.monitor();
hardware is esp 32 and jyqc_v6.3e1 driver and 2pole bldc mptor
