Velocity Control
Hey guys!
I have a problem with my motor control especially in terms of velocity control. I already implemented velocity control and angle control and now i have bought a new motor and suddenly to code which was working fine isn‘t working anymore.
Therefore i tried to use torque control with my new motor and this was working perfectly fine while using angle control wouldn‘t work. When I use angle control or velocity control my motor isn‘t spinning at all. Is there maybe a problem with my parameters of my PID regelator? As mentioned before I already inplemented velocity and angle control with a other motor.
Kind regards
Leon
Hi Leon,
It could be an issus with the PID gains, did you try to re-tune when you changef the motor?
Did the type of motor change a lot?
Do you use current sensing?
Typically, motors requiring higher currents (ex. drone motors) will require lower gains, and motors requiring lower currents (ex. gimbal motors) will need higher gains.
Thanks for the response!
I tried to re-tune the PID gains but I can’t figure out the perfect gains.
My motor requiers currents about 600mA and the motor I used before also needed about 600mA. The motor I used before was a maxon ec flat and currently I am using a Nanotec DB28S01.
Current sensing is in my application not available.
Sorry @leon1,
As far as I could find, Nanotec DB28S01 has relatively high phase resistance of around 8 Ohm. While es flat are usually lower resistance, but of course that all depends on the exact motor parameters.
Could we see your code maybe? It would help to debug.
Are you using the same sensor for both motors and the same MCU?
What is the exact behavior that you have once you use the velocity control, the motor does not move at all? No noise? No vibration?
The motor starts to vibrate but isn’t spinning. I am currently using the ESP32 an hall sensors as I also did with my other motor.
Here is my code:
#include <SimpleFOC.h
 int U_EN = 18;   // inhu
 int V_EN = 5;  // inhv
 int W_EN = 17;  // inhw
 float target_velocity = 0;
  // Motor instance
 BLDCMotor motor = BLDCMotor(2);
 // driver instance
 BLDCDriver3PWM driver = BLDCDriver3PWM(16, 4, 32);
 HallSensor sensor = HallSensor(25, 26, 27, 2);
 // channel A, B and C callbacks
 void doA(){sensor.handleA();}
 void doB(){sensor.handleB();}
 void doC(){sensor.handleC();}
   pinMode(U_EN, OUTPUT);
   pinMode(V_EN, OUTPUT);
   pinMode(W_EN, OUTPUT);
   digitalWrite(U_EN, HIGH);
   digitalWrite(V_EN, HIGH);
   digitalWrite(W_EN, HIGH);
   // initialize sensor hardware
   // hardware interrupt enable
   // link the motor and the sensor
   // driver init
   if(!driver.init()){
     return;
   // link driver
   // aligning voltage [V]
   motor.voltage_sensor_align = 2.2f;
   // contoller configuration
   motor.PID_velocity.P = 0.1f;
   motor.PID_velocity.I = 0.1f;
   motor.voltage_limit = 12;
   // align sensor and start FOC
   // Arduino UNO loop  ~1kHz
   // Bluepill loop ~10kHz
   // motor.monitor();
Thanks for your help!
I imagine that ec flat motor had more pole pairs right?
2 pole pairs is very low this might be causing some issues with the alignment.
Can you try using the hall sensor without the interrupt?
It should be working if you just comment out this code.
The alignment process is successful but I will try it without this line.
And you are right the ec flat had more polepairs
Since your torque control works well you’re probably right, it’s probably not the alignment.
But wat it could be is the velocity calculation that is pretty bad at least for low velocities.
There are couple of things you can do:
  1. Increase the velocity filtering values:
motor.LPF_velocity.Tf = 0.01; // in sec - by default is 0.001 - 1ms I think
The higher the value the more smooth the velocity will be but also more lag so do not put it to high.
  1. (BETTER OPTION) Increase the minimal time between velocity calculations
sensor.min_elapsed_time = 0.0001; // 100us by default
The higher it is the less often the velocity will be calculated and in that case the more smooth the values will be.
Thank you very much i will try these options tomorrow.
Could this also be a solution to implement the angle control which shows the same behaviour?
Yes, since the angle control wraps the velocity control, if the velocity control is not responding the angle control will not work either.
Thank you for your expertise!
Thank you very much increasing the velocity filtering values was the solution for my problem!
But I have another question: How can I achieve higher speeds for my angle control?
This is my current code:
float target_angle = 0; //= 6.28;
 // Motor instance(pp)
// driver instance
  // driver init
  if(!driver.init()){
    return;
  // link driver
  // aligning voltage
  motor.PID_velocity.P = 0.2f;
  motor.PID_velocity.I = 0.20f;
  motor.LPF_velocity.Tf = 0.1f;
  // angle P controller
  motor.P_angle.P = 10;
  // acceleration control using output ramp
  // this variable is in rad/s^2 and sets the limit of acceleration
  motor.P_angle.output_ramp = 10000;
  motor.velocity_limit = 40;
  motor.move(target_angle);
  // motor.monitor();
You should be able to get higher velocities if you increase this limit value.
