Using AS5600 as a post-gear position sensor
Hello.
I would like to use AS5600 (i2c) to position the arm approximately 180*(+/-90*) through a 35/1 bevel gear. I use a BLDC motor controlled by hall sensors.
I am thinking of controlling several such controllers using the i2ccommander module. Can this work?
Yes, it can work
They all need different I2C addresses, of course.
When you call the angle or velocity normally, it will be the one from the Hall sensors.
To get the extra AS5600 values you’ll have to add a custom register for it. It’s not hard to do, we can help you with that if you have troubles.
