Hello everyone! I use v2.0.2 shield to run the angle control of simpleFOC, and use the FOC current control inside. But after my operation, my motor spins wildly, I don’t know why? This is my code, thanks
MagneticSensorSPI sensor = MagneticSensorSPI(9, 14, 0x3FFF);
BLDCDriver3PWM driver = BLDCDriver3PWM(10, 5, 6, 8);
InlineCurrentSense current_sense = InlineCurrentSense(0.01, 50.0, A1, A3);
float target_angle = 0;
void onMotor(char* cmd){ command.motor(&motor,cmd); }
current_sense.gain_b *= -1;
current_sense.init();
motor.PID_velocity.P = 0.2;
motor.PID_velocity.I = 10;
motor.P_angle.P = 10;
motor.voltage_limit = 6;
motor.velocity_limit = 5;
motor.LPF_velocity.Tf = 0.01;
command.add('M',onMotor,"my motor");
motor.move(target_angle);
