Two Motors one MCU - motors going berserk
I am having a bit of a problem with two motors on one MCU. I haven’t had the chance to debug anything yet, so feel free to chip in with any ideas for deeper analysis.
MCU: STM32 Black Pill STM32F401CCU6
Driver: BTS7960
Motor: Hoverboard, 250W, Hall sensors
The code runs perfectly fine with one motor, but not with two (pls ignore the I2C code - not used yet, the commands are being sent via serial commander).
#include "SimpleFOCDrivers.h"
#include "comms/i2c/I2CCommander.h"
#define SERIAL_COMMANDER
#define MOTOR1
//#define MOTOR2
#define PP 15
#define HZ  5000
#define V_PSU 12    //driver1.voltage_power_supply
#define V_LIM 12    //driver1.voltage_limit
#define V_MOT_LIM 6  //motor1.voltage_limit
#define V_MOT_LIM_INIT 6 //motor1.voltage_limit
#define V_MOT_SENS_ALIGN 3  //motor1.voltage_sensor_align
#define MOT_P 0.2f
#define MOT_I 2
#define MOT_D 0
#define MOT_PID_RAMP 1000
#define MOT_LPF 0.05f // expected 0.005-0.01f (in sec)
#define SDA_PIN         PB4
#define SCL_PIN         PA8
int rcvnr = 0;
int serial_loop = 0;
//int a = 0;
TwoWire Wire2(SDA_PIN, SCL_PIN);
// I2C commander instance
uint8_t i2c_addr = 0x61;  // can be anything you choose
I2CCommander commander(&Wire2);
void onReceive(int numBytes) {
  commander.onReceive(numBytes);
  rcvnr++;
void onRequest() {
  commander.onRequest(); }
#ifdef SERIAL_COMMANDER
  float target_velocity = 0;
  float target_P = 0;
  float target_I = 0;
  float target_D = 0;
#endif
#ifdef MOTOR1
  BLDCMotor motor1 = BLDCMotor(PP);
  BLDCDriver3PWM driver1 = BLDCDriver3PWM(PB0, PA7, PA6, PB1);
  HallSensor sensor1 = HallSensor(PB12, PB13, PB14, PP);
  void doA1(){sensor1.handleA();}
  void doB1(){sensor1.handleB();}
  void doC1(){sensor1.handleC();}
#endif
#ifdef MOTOR2
  BLDCMotor motor2 = BLDCMotor(PP);
  BLDCDriver3PWM driver2 = BLDCDriver3PWM(PA2, PA1, PA0, PA3);
  HallSensor sensor2 = HallSensor(PB8, PB7, PB6, PP);
  void doA2(){sensor2.handleA();}
  void doB2(){sensor2.handleB();}
  void doC2(){sensor2.handleC();}
#endif
  delay(2000);
  SimpleFOCDebug::enable();
  #ifdef MOTOR1
    sensor1.pullup = Pullup::USE_INTERN;
    sensor1.init();
    sensor1.enableInterrupts(doA1, doB1, doC1);
    motor1.linkSensor(&sensor1);
    driver1.pwm_frequency = HZ;
    driver1.voltage_power_supply = V_PSU;
    driver1.voltage_limit = V_LIM;
    driver1.init();
    motor1.linkDriver(&driver1);
    motor1.voltage_limit = V_MOT_LIM_INIT;
    motor1.voltage_sensor_align = V_MOT_SENS_ALIGN;
    motor1.controller = MotionControlType::velocity;
    motor1.PID_velocity.P = MOT_P;
    motor1.PID_velocity.I = MOT_I;
    motor1.PID_velocity.D = MOT_D;
    motor1.PID_velocity.output_ramp = MOT_PID_RAMP;
    motor1.LPF_velocity.Tf = MOT_LPF;
    delay(2000);
    Serial.println("Motor 1");
    motor1.useMonitoring(Serial) ;
    motor1.init();
    motor1.initFOC(); // motor1.initFOC(2.1, CCW);
    motor1.voltage_limit = V_MOT_LIM;
  #endif
  #ifdef MOTOR2
    sensor2.pullup = Pullup::USE_INTERN;
    sensor2.init();
    sensor2.enableInterrupts(doA2, doB2, doC2);
    motor2.linkSensor(&sensor2);
    driver2.pwm_frequency = HZ;
    driver2.voltage_power_supply = V_PSU;
    driver2.voltage_limit = V_LIM;
    driver2.init();
    motor2.linkDriver(&driver2);
    motor2.voltage_limit = V_MOT_LIM_INIT;
    motor2.voltage_sensor_align = V_MOT_SENS_ALIGN;
    motor2.controller = MotionControlType::velocity;
    motor2.PID_velocity.P = MOT_P;
    motor2.PID_velocity.I = MOT_I;
    motor2.PID_velocity.D = MOT_D;
    motor2.PID_velocity.output_ramp = MOT_PID_RAMP;
    motor2.LPF_velocity.Tf = MOT_LPF;
    Serial.println("Motor 2");
    motor2.useMonitoring(Serial) ;
    motor2.init();
    motor2.initFOC(); //motor2.initFOC(0.13, CCW);
    motor2.voltage_limit = V_MOT_LIM;
  #endif
  digitalWrite(SDA_PIN, LOW);
  digitalWrite(SCL_PIN, LOW);
  Wire2.begin(i2c_addr, true);
  #ifdef MOTOR1
    commander.addMotor(&motor1);
  #endif
  #ifdef MOTOR2
    commander.addMotor(&motor2);
  #endif
  commander.init(i2c_addr);
  Wire2.onReceive(onReceive);
  Wire2.onRequest(onRequest);
  #endif
  delay(1000);
  #ifdef MOTOR1
    motor1.loopFOC();
    motor1.move(target_velocity);
  #endif
  #ifdef MOTOR2
    motor2.loopFOC();
    motor2.move(target_velocity);
  #endif
  if(serial_loop==100) {
    // serial output
    serial_loop = 0;
  serial_loop++;
  //motor1.monitor();
When I add the second motor and send T1 over the commander, both motors run a lot faster than 1rad/s and stop.
While a single motor is enabled, T1 makes the enabled motor run at 1 rad/sec.
Any ideas on what to look into here are welcome.
Is it possible that this behavior can be caused by my “weird” choice of pins for the phases?
Your code looks ok, actually. Maybe I just can’t spot the issue.
In general, two motors is possible on STM32, esp in 3PWM mode it should be no problem.
You can add the -D SIMPLEFOC_STM32_DEBUG flag, and then it will print some debug information about the timers used. That will answer the question whether the pins used are a problem. But if you say either motor is working well alone, then its likely the pins are ok. Unless some of the pins are actually on the same timer output…
You might want to reduce the amount of stuff happening, (like, remove the I2C code, switch off the monitoring for the motors) and see what kind of loop speed you’re getting. 2 hall sensors and everything else might be too much going on…
Another thought is regarding the PSU - can it handle both motors? They get switched on at the same time, so maybe one motor alone is within its power range, but two at the same time is overloading it?
Thank you.
I have a very bad PSU - I’ll test it with another one.
Here’s the output of the timers configuration with the debug on.
TIM3-CH3 TIM3-CH2 TIM3-CH1 score: 1
STM32-DRV: best: TIM3-CH3 TIM3-CH2 TIM3-CH1 score: 1
STM32-DRV: Configuring high timer 3
STM32-DRV: Configuring high channel 3
STM32-DRV: Configuring high channel 2
STM32-DRV: Configuring high channel 1
STM32-DRV: Restarting timer 3
Motor 1
MOT: Monitor enabled!
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: sensor_direction==CCW
MOT: PP check: OK!
MOT: Zero elec. angle: 2.09
MOT: No current sense.
MOT: Ready.
TIM5-CH3 TIM5-CH2 TIM5-CH1 score: 1
TIM9-CH1 TIM5-CH2 TIM5-CH1 score: 2
STM32-DRV: best: TIM5-CH3 TIM5-CH2 TIM5-CH1 score: 1
STM32-DRV: Configuring high timer 5
STM32-DRV: Restarting timer 5
Well, that’s a perfectly good combination for 3-PWM on 2 motors, and the initialisation is happy with it. For motor 2, it correctly picks the timer channels all belonging to the same timer.
So its not an issue with the pins…
PP check is passing, so that’s also encouraging.
Hoverboard motors can use quite some current, so maybe the PSU is a good thing to check.
I replaced one hall sensor cable and seems to work now. It seems that starting the second motor just added noise to the hall sensors and it went randomly nuts. Thanks
@runger I have a hard time understanding how is this even possible…
Both motors try to hold the position after initialization.
When I start one motor and move the other by hand, things get weird: the motor that is supposed to hold position tries to do that only in one direction, but instead of stopping, it continues to rotate in the opposite direction of the force it’s trying to counter - both motors quickly stop.
I made a quick video demonstrating this behavior.
As you can see from the video, the cabling is as bad as it can get - I will eventually replace it all, but it doesn’t make sense to me to blame the cabling again for this (but it could well be the reason, I just don’t understand how).
Do you have any other ideas or suggestions?
