I see a nice trim pot on the board for adjusting speed. Am i able to use the trim pot with SimpleFOC to fine tune the speed in OpenLoop during operation? (There was some drift at times with the Shield)
My application is a turntable, so fine tuning and speed stability are my most important needs.
No, it only supports 3PWM (with another 3 EN signals, but these are on a different timer). This is different from 6PWM.
The PWM pins are PA8/9/10, and the enable are PC10/11/12.
Yes you can read the trimpot and use this for speed control.
The shield actually also supports ABZ/UVW encoders, and SPI1 is still available through the shield, so if you want an encoder, you can get it working. There are some other threads on this forum about building a turntable that may be helpful. Especially, you need to make sure that your board has an external clock (HSE). The default on the G474RE is HSI, I don’t know if there is an external clock fitted or not.
Yes, I have the G474 running with HSE. It has a crystal oscillator. Much better speed stability than the F446 board which just has HSI. (Thanks to jazzboy for figuring that issue out out)
