Hi everyone, thanks for your help in advance!
I’m getting the B-G431B-ESC1 to run some simple skateboard hub motors that use hall sensors.
I’ve been messing around with the settings to try and get high torque at low speeds. I saw that it was reccomended to use motor.foc_modulation = FOCModulationType::Trapezoid_120
Unfortunately when I did this, my motor made a loud noise and the ESC doesn’t work anymore.
Later on (today) I tried using it again and it blew up another of my ESCs.
The code is attached below.
#define MAX_SPEED 20
#define PP 10
BLDCMotor motor = BLDCMotor(PP, 0.8, 66);
LowsideCurrentSense currentSense = LowsideCurrentSense(0.003f, -64.0f / 7.0f, A_OP1_OUT, A_OP2_OUT, A_OP3_OUT);
HallSensor sensor(A_HALL1, A_HALL2, A_HALL3, PP);
void hallA() {
sensor.handleA();
void hallB() {
sensor.handleB();
void hallC() {
sensor.handleC();
//target variable
float targetVelocity = 0;
void doTarget(char* cmd) {
command.scalar(&targetVelocity, cmd);
// void doLimit(char* cmd) {
// command.scalar(&motor.voltage_limit, cmd);
driver.voltage_power_supply = 22;
//driver.voltage_limit = 10;
sensor.enableInterrupts(hallA, hallB, hallC);
// limiting motor movements
//motor.voltage_limit = 5; // [V]
motor.current_limit = 3;
// open loop control config
// Voltage torque control has more torque at low speeds
motor.foc_modulation = FOCModulationType::Trapezoid_120;
motor.LPF_angle.Tf = 0.4;
// init motor hardware
currentSense.init();
// command.add('L', doLimit, "voltage limit");
// foc and motion controls
motor.move(targetVelocity);
