Torque control does not spin motor
I’m a bit stumped here. I’m trying to get torque control working and tuned but the only thing I manage to get is a locked motor. It target the current correctly but I get no motion no matter how much currently I put through this thing.
I’m using an esp32 s3 with low side sensing and a custom encoder. I’ve verified the encoder actually reads the correct angle. I’ve tried clockwise and counter clockwise rotation.
I’ve also tuned the current q and d PID loops to see if that would help. It did not.
Voltage control, DC current control, and FOC current control all give the same results, the correct target current with a locked rotor.
Attached is my cleaned code. I’ve removed quite a bit of custom stuff that I think is irrelevant.
#include “HardwareSerial.h”
#include “esp32-hal.h”
// Irrelevant includes //
// Pin definitions for other libs //
// Monitoring setup
#define   _MON_TARGET 0b1000000  // monitor target value
#define   _MON_VOLT_Q 0b0100000  // monitor voltage q value
#define   _MON_VOLT_D 0b0010000  // monitor voltage d value
#define   _MON_CURR_Q 0b0001000  // monitor current q value - if measured
#define   _MON_CURR_D 0b0000100  // monitor current d value - if measured
#define   _MON_VEL    0b0000010  // monitor velocity value
#define   _MON_ANGLE  0b0000001  // monitor angle value
// — DRV8323S Library Instance — //
// A quick delay function
void short_yield_to_idle(void) {
TaskHandle_t self = xTaskGetCurrentTaskHandle();
UBaseType_t orig_pri = uxTaskPriorityGet(self);
if (orig_pri > tskIDLE_PRIORITY) {
// lower priority by 1 so IDLE (priority tskIDLE_PRIORITY) becomes runnable
vTaskPrioritySet(self, orig_pri - 1);
taskYIELD();                      // immediate context switch
vTaskPrioritySet(self, orig_pri); // restore
} else {
// already idle-priority: yield once
taskYIELD();
BLDCMotor motor = BLDCMotor(7, 0.027, 2800);
// BLDCDriver6PWM driver setup
BLDCDriver6PWM driver = BLDCDriver6PWM(1, 2, 3, 4, 5, 6);
Commander command = Commander(Serial); // Use Serial for commander
// LowsideCurrentSense(shunt_resistance, gain, adc_a, adc_b, adc_c)
LowsideCurrentSense current_sense = LowsideCurrentSense(0.001, -20, 10, 9, 8);
// Set up the ADCs for low side current sensing
analogSetAttenuation(ADC_11db);  // Sets 0-3.3V range for all ADC pins
Serial.begin(115200); // Use Serial for initialization
// Configure and enable DRV8323S enable pin at the very beginning
while(!Serial) {
    delay(10); // Wait for USB CDC connection
// Initialize SPI Bus
// Initialize the DRV8323S (use_csa = true for current sensing)
// Actually keeping this part since it deals with my CSA
// Configure custom OCP settings if needed (optional)
OcpControl ocp = drv8323.getOcpControl();
ocp.vds_lvl = VdsLvl::V0_26;  // 0.26V threshold
ocp.ocp_mode = OcpMode::ReportOnly;
drv8323.setOcpControl(ocp);
// Configure custom CSA settings if needed (optional)
CsaControl csa = drv8323.getCsaControl();
csa.csa_fet = false;
csa.vref_div = false;
csa.ls_ref = false;
csa.csa_gain = CsaGain::G40;
csa.dis_sen = false;
csa.csa_cal_a = false;
csa.csa_cal_b = false;
csa.csa_cal_c = false;
csa.sen_lvl = SenLvl::V0_25;
drv8323.setCsaControl(csa);
// Read the fault registers just in case
// --- Driver --- //
driver.voltage_power_supply = 7.5;
// Set the pwm to 20khz
driver.pwm_frequency = 20000;
// Initialize the driver.
// --- Custom encoder setup --- //
// Initialize sensor
// Option 1: Run calibration (spin motor by hand for 10 seconds)
sensor.calibrate(10000);
// --- Control Type --- //
// Set up velocity control
// Use FOC current control
// --- Motor Values --- //
// Cap the current at a maximum level
motor.current_limit = 12; // amps
// Cap the driver voltage
motor.voltage_limit = 0.4; // about 14 amps
// Link the positional sensor
// --- Current Sensing --- //
// Link the current sensing and initialize it
// init current sense
if (current_sense.init())
    Serial.println("Current sense init success!");
else{
    Serial.println("Current sense init failed!");
    return;
// link the motor and the current sensor
// --- PID Values --- //
motor.LPF_velocity.Tf = 0.02;
// current q loop PID
motor.PID_current_q.P = 0.2;
motor.PID_current_q.I = 0.5;
motor.PID_current_q.D = 0.0;
motor.PID_current_q.output_ramp = 0.0;
motor.PID_current_q.limit = 0.4;
motor.LPF_current_q.Tf = 0.1;
// current d loop PID
motor.PID_current_d.P = 0.6;
motor.PID_current_d.I = 0.8;
motor.PID_current_d.D = 0.0;
motor.PID_current_d.output_ramp = 0.0;
motor.PID_current_d.limit = 0.4;
motor.LPF_current_d.Tf = 0.1;
// initialise motor
// skip alignment procedure
// current_sense.skip_align = true;
// invert phase gains
current_sense.gain_a *= -1;
current_sense.gain_b *= -1;
current_sense.gain_c *= -1;
// Set the motor to check the angle every 5 foc calls
motor.motion_downsample = 5;
// Set the expected direction for the sensor
motor.sensor_direction = Direction::CCW; // Direction::CW;
// Initialize FOC
motor.target = 0;
// define the motor id
motor.monitor_variables = _MON_TARGET | _MON_VOLT_Q | _MON_VOLT_D | _MON_CURR_Q | _MON_CURR_D | _MON_VEL | _MON_ANGLE;
motor.monitor_downsample = 10; // default 10
// main FOC algorithm function, the higher the execution frequency, the better, don't put delays in the loop
// this function can be run at much lower frequency than loopFOC()
// significantly slowing the execution down
// Allow the watchdog time to catch up
short_yield_to_idle();
Open loop velocity and position work just fine. Cogging is noticeable there but it’s not bad.
You need to set motor.torque_controller = TorqueControlType::foc_current; for it to use hardware current sense. It’s using estimated current from the motor parameters right now.
Is there a reason you pass a negative gain to the current sense constructor and then multiply the gains by -1 later?
Have you tried manually adjusting zero_electric_angle?
No change. It still just locks into place.
I forgot to comment out the multiplication of negative gain when I was debugging. Fixing this does not change its behavior.
I have not. My cat just gave my board a good sniff and ESDed it to death.
I guess this project once again goes on hiatus for a few months.
IT LIVES.
Back to the manually adjusting the electric angle. How should I do that? The alignment check always gives 0 for that value.
I’ve never used Commander myself, but I think you create a function like
void doZeroAngle(char* cmd) { motor.zero_electric_angle = atof(cmd); }
And then in setup(),
command.add('Z', doZeroAngle, "set zero angle");
It’s also possible the sensor direction is wrong. You could try running in open loop velocity mode and see if sensor.getAngle() increases or decreases when target is set to a positive value. If it increases use Direction::CW, if it decreases use CCW.
It might be smarter to debug why the sensor isn’t working during calibration in the first place, but in my experience the zero angle usually needs some manual refinement anyway. Use torque mode to spin one way and then the other and adjust zero angle until both directions are the same speed.
My sensor was in fact backwards. Its clockwise not counter clockwise apparently.
But I have stepped through zero values of 0-7 in 0.1 increments and none have allowed this to spin in torque mode.
This is me spinning the motor by hand CW
Is 7 in fact the correct number of pole pairs for your motor?
I’m pretty certain it has 14 poles so I think 7 is correct
Right now my suspicion is that my library was borked so I took that as an opportunity to switch to platformIO.
Still working on getting it running though. Something in my encoder library currently does not play well with it.
Ok. So I have switched to platformIO.
Here is my platformio.ino file that finally worked.
[env:esp32-s3-fh4r2]
platform = https://github.com/pioarduino/platform-espressif32
board = esp32-s3-fh4r2
framework = arduino
lib_archive = false
lib_deps = askuric/Simple FOC@^2.3.5
build_flags =
    -DCONFIG_FREERTOS_HZ=1000
    -DARDUINO_USB_CDC_ON_BOOT=1
    -DARDUINO_USB_MODE=1
    -DCORE_DEBUG_LEVEL=0
board_build.tasks.stack_size = 8192
I still however have issues with torque control. The motor just doesn’t want to spin. I’ve only managed to get it to spin, albeit very poorly, by allowing my current sense to do the auto alignment, and repeatedly setting my electrical angle to 5.9 until it decides to spin.
Here is the output from the one time it actually spun.
Zero angle set to: 5.90
MOT: Align sensor.
MOT: Skip dir calib.
MOT: Skip offset calib.
MOT: Align current sense.
CS: Switch B-C
CS: Inv C
MOT: Success: 4
MOT: Ready.
Its odd that it wants to switch B and C as well as invert C. That makes no sense to me. My wiring is good so I don’t understand why this was the only one to spin.
I’ve manually set these values but have yet to reproduce motion on the motor.
I’m terribly confused.
