Test SimpleFOClibrary + SimpleFOCMini + RP2040-Zero + 2804 + AS5600
Good morning,
And congratulations to all the developers for this superb work :slight_smile:
My test setup:
BLDC Motor 2804 + AS5600 ==> MKS YT2804
https://uk.aliexpress.com/item/1005005065257355.html
Driver FOC ==> SimpleFOCMini (China… sorry)
MicroController ==> RP2040-Zero
First test with version 2.3.0 ==> adc error impossible to compile…
Second test with the github “dev” version, everything is ok :slight_smile:
The current test code for SimpleFOCStudio not optimized, I will add a video when everything is ready.
#include <Wire.h> // penser a changer pins I2C dans setup !
#define SIMPLEFOC_PWM_ACTIVE_HIGH true
int OUT1 = 29; // pin out1
int OUT2 = 28; // pin out2
int OUT3 = 27; // pin out3
int MOTOR_ENABLE = 26; // pin enable
float MotorResInOhms = 8.6;
float MotorInAmps = 0.240;  // 180 M-Amps
float PowerInVolts = 12;
float SensorOffset = 0;
int MOTORE_POLE_NB = 7; // 7 Nombre de poles du BLDC
float MOTOR_KV_RATING = 320; // motor.KV_rating = MOTOR_KV_RATING;  rpm/volt - default not set
BLDCMotor motor = BLDCMotor(MOTORE_POLE_NB); // Nombre de pôles du moteur
BLDCDriver3PWM driver = BLDCDriver3PWM(OUT1, OUT2, OUT3, MOTOR_ENABLE); //  3 phases + enable
//MagneticSensorI2C sensor = MagneticSensorI2C(AS5600_I2C);
// SimpleFOCStudio
void doMotor(char* cmd) {
  command.motor(&motor, cmd);
//▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬setup▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬
  delay(500);
  //▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬sensor_config▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬
  Wire.setClock(1000000); // Try calling Wire.setClock(400000) or 1000000 or 3400000 to speed up the i2c bus.
  Wire.setSDA(0); // pin SDA
  Wire.setSCL(1); // pin SCL
  Wire.begin();
  delay(500);
  // providing
  // sensor.min_elapsed_time = 0.0001; // 0.0001 ==> 100us by default ==>  10000 Hz ==> 10Khz
  sensor.init(&Wire);
  //▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬driver_config▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬
  driver.voltage_power_supply = PowerInVolts;
  // Max DC voltage allowed
  driver.voltage_limit = PowerInVolts;
  driver.pwm_frequency = 100000; // 100000
  // init driver
  if (driver.init())  Serial.println("Driver init success!");
  else {
    return;
  //▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬motor_config▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬
  // choose FOC modulation
  // FOCModulationType::SinePWM;
  motor.foc_modulation = FOCModulationType::SinePWM; //  SinePWM SpaceVectorPWM
  // set torque mode to be used
  // TorqueControlType::voltage    ( default )
  // TorqueControlType::dc_current
  // TorqueControlType::foc_current
  // Closed-Loop control
  //SimpleFOClibrary gives you the choice of using 3 different Closed-Loop control strategies:
  // MotionControlType::torque
  // MotionControlType::velocity
  // MotionControlType::angle
  // contoller configuration
  motor.PID_velocity.P = 0.2f; // 0.2f 0.8f
  motor.PID_velocity.I = 20.0f; // 20
  motor.PID_velocity.D = 0.001; // 0.001 / 0
  motor.PID_velocity.output_ramp = 1000; // 1000
  // setting the limits
  motor.velocity_limit = 20; // rad/s - default 20 (limite vitesse & 6 vitese est lent mais ok)
  motor.LPF_velocity.Tf = 0.6f; // 0.01f
  // https://docs.simplefoc.com/cheetsheet/options_reference
  // angle PID controller
  // default P=20
  motor.P_angle.P = 10.0f; // 6 20  80 (faible amortis l'arrêt)
  motor.P_angle.I = 0;  // 0 usually only P controller is enough
  motor.P_angle.D = 0;  // 0 usually only P controller is enough
  // acceleration control using output ramp
  // this variable is in rad/s^2 and sets the limit of acceleration
  motor.P_angle.output_ramp = 10000; // 10000 // default 1e6 rad/s^2
  // angle low pass filtering
  // default 0 - disabled
  // use only for very noisy position sensors - try to avoid and keep the values very small
  motor.LPF_angle.Tf = 0.0001; // default 0
  // sensor offset [rad]
  motor.sensor_offset = SensorOffset; // default 0 rad (dcaler offset 0 sur capteur/encodeur=
  // limiting voltage
  motor.voltage_limit = PowerInVolts;   // limiting Voltage Volts
  // Global current limit. Limits Q-axis current.
  motor.current_limit = MotorInAmps; // 180 M-Amps
  // motor phase resistance [Ohms]
  motor.phase_resistance = MotorResInOhms; //
  // motor KV rating [rpm/V]
  //KV = velocity_at_one_volt * 30/pi
  motor.KV_rating = MOTOR_KV_RATING; // rpm/volt - default not set
  //▬▬▬▬▬▬▬▬Velocity PID controller output limit. Set to limit velocity to this maximum.
  // ATTENTION volts ou amps ???
  // https://community.simplefoc.com/t/setting-current-limits-in-main-loop/1972/2
  motor.PID_velocity.limit = 12;
  // aligning voltage [V]
  motor.voltage_sensor_align = 6; // default 3V
  // incremental encoder index search velocity [rad/s]
  motor.velocity_index_search = 3; // default 1 rad/s
  // Set to values > 1 to reduce how often move() is executed compared to loopFOC().
  // On fast MCUs it makes sense to reduce how often move() gets called.
  motor.motion_downsample = 0;
  motor.sensor_direction = Direction::CCW; // CW or CCW
  // align sensor and start FOC
  // https://github.com/simplefoc/Arduino-FOC/blob/dev/src/common/defaults.h
  // https://docs.simplefoc.com/commander_interface
  // https://docs.simplefoc.com/commander_motor
  // https://docs.simplefoc.com/commander_target
  // https://docs.simplefoc.com/studio
  // add the motor to the commander interface
  // The letter (here 'M') you will provide to the SimpleFOCStudio
  //command.add('M', doMotor, "My motor motion");
  command.decimal_places = 4; // default 3 (moi 4)
  // tell the motor to use the monitoring
  motor.monitor_downsample = 0; // 0 = disable monitor at first - optional
} // End_setup
//▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬End_setup▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬
//▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬loop▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬
  //Serial.print(String(sensor.getAngle()) + "\t" + String(sensor.getVelocity()) + "\t" + String(((sensor.getAngle()-motor.sensor_offset)*180/_PI)) + "\n");
} // End_loop
//▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬End_loop▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬▬
I would reduce the sensor align voltages, that could overheat your motor. Also the
line, I think I might have had to change that, there is an error with one of the examples on that line. The E needs to be a C or something, I forget.
In general it is more advisable to get the motor working open loop at low voltage, and get the sensor reading reliably, first.
These sensors benefit seriously from the “calibration” procedure. Much better energy efficiency is obtained as motor timing is better.
Also there are a number of other details like the direction pin, some as5600 sensor boards need to have that grounded, that sort of thing is what the other testing stages is for. To check all wiring etc. However it looks promising. Exactly how did you attach the magnet to the motor? I printed a little magnet holder and that worked well for the magnet that usually comes with these sensors.
Hello Anthony,
Thank you for your tips :slight_smile:
The motor I use is sold with magnet attached and support for AS5600
But you are right I also use 3D printing if I need to fix
I still have a lot of settings to discover to hope to use suimpleFOC correctly
It’s starting to work fine :slight_smile:
I still have to familiarize myself with all the possibilities of SimpleFOC
There is still a little vibration when stopped in “Angle” mode
The current code
  Encodeur Magnétique ==> AS5600
  Moteur BLDC ==> MKS YT2804
  Driver FOC ==> SimpleFOCMini (China... sorry)
  MicroControleur ==> RP2040-Zero
  https://www.waveshare.com/wiki/RP2040-Zero
  https://www.waveshare.com/wiki/RP2040-ZeroWS2812B
  WS2812B GPIO16
  https://docs.simplefoc.com/citing
  https://github.com/earlephilhower/arduino-pico
  https://github.com/MrYsLab/NeoPixelConnect
#include <NeoPixelConnect.h>
float MotorResInOhms = 2.6; //
float MotorInAmps = 1.0;  // 180 M-Amps
float SensorOffset = 0.60;
float MOTOR_KV_RATING = 320; // 432.14; // motor.KV_rating = MOTOR_KV_RATING;  rpm/volt - default not set
BLDCMotor motor = BLDCMotor(MOTORE_POLE_NB); // ??????? Nombre de pôles du moteur
BLDCDriver3PWM driver = BLDCDriver3PWM(OUT1, OUT2, OUT3, MOTOR_ENABLE); // ??????? 3 phases + enable
//MagneticSensorI2C sensor = MagneticSensorI2C(0x36, 12, 0x0E, 4);
// SimpleFOCStudio
#define MAXIMUM_NUM_NEOPIXELS 1
int NeoPixelPin = 16;
int Intensity = 200;
NeoPixelConnect p(NeoPixelPin, MAXIMUM_NUM_NEOPIXELS, pio0, 0);
  // Led
  p.neoPixelFill(0, Intensity, 0, true);
  p.neoPixelClear(true);
  delay(500);
  Wire.begin();
  delay(500);
  // providing
  sensor.init(&Wire);
  // init driver
  else {
    return;
  motor.velocity_limit = 100; // rad/s - default 20 (limite vitesse & 6 vitese est lent mais ok)
  motor.LPF_velocity.Tf = 0.04f; // 0.01f ==> max 0.06 après vibre en mode velocity !
  // default P=20
  motor.P_angle.P = 20.0f; // 6 20  80 (faible amortis l'arrêt)
  motor.LPF_angle.Tf = 0; // default 0
  // limiting voltage
  motor.voltage_limit = 3; // PowerInVolts  // limiting Voltage Volts
  //motor.KV_rating = MOTOR_KV_RATING; // rpm/volt - default not set
  motor.voltage_sensor_align = 3; // default 3V
  motor.sensor_direction = Direction::CW; // CW or CCW
  motor.zero_electric_angle = 6.2280;
  // Led
  p.neoPixelFill(Intensity, 0, 0, true);
} // End_setup
  // calculate the KV
  //Serial.println(motor.shaft_velocity / motor.target * 30.0f / _PI);
} // End_loop
A short video (Sorry I’m not good at amateur video :-p )
https://youtu.be/CqxPtJRbVbk
