Hi guys,
Finally, 6pwm drivers will be supported on Teensy 4.x boards. The code is in the dev branch and will be officially included in the next release.
For now simplefoc will support the 6PWM using the FlexTimers and its channels A and B. Similar could be done using QuadTimers but it would add a lot of complexity, so no support for now, but if there is an interest in such a solution we’d be happy to try it out. ![]()
Supported pinouts
Teensy4.x 6pwm driver generates a 6pwm signal using FlexTimers.
Each high-low pair of the 6pwm has to be A and B channels of the same FlexTimer and to the same submodule .
You can find more info about the available FlexTimer pwm pins per teensy 4.x board in the teensy documentation:
List of available Teensy 4.1 pins which can be used for the 6pwm driver with their respective submodules and channels:
| FlexTimer | submodule | channel | pin number |
| FlexPWM4 | 2 | A | pin 2 |
| FlexPWM4 | 2 | B | pin 3 |
| FlexPWM1 | 3 | B | pin 7 |
| FlexPWM1 | 3 | A | pin 8 |
| FlexPWM2 | 2 | A | pin 6 |
| FlexPWM2 | 2 | B | pin 9 |
| FlexPWM3 | 1 | B | pin 28 |
| FlexPWM3 | 1 | A | pin 29 |
| FlexPWM2 | 3 | A | pin 36 |
| FlexPWM2 | 3 | B | pin 37 |
| FlexPWM1 | 1 | B | pin 42 |
| FlexPWM1 | 1 | A | pin 43 |
| FlexPWM1 | 0 | B | pin 44 |
| FlexPWM1 | 0 | A | pin 45 |
| FlexPWM1 | 2 | B | pin 46 |
| FlexPWM1 | 2 | A | pin 47 |
IMPORTANT
Make sure that you connect your driver’s high side input to the Teensy pin which corresponds to the channel A and the low-side to the channel B!
For each hiigh-low combination of your driver make sure to choose the pins which belong to the same t FlexTimer and the same submodule.
Example code
There is an example code in the library examples folder that you can use to start off your applications.
// 6pwm standalone example code for Teensy 4.x boards
// Teensy4.x 6pwm driver generates a 6pwm signal using FlexTimers and it doesn't support the QuadTimers
// - Each high-low pair of the 6pwm has to be A and B channels of the same FlexTimer and to the same submodule
// List of available teensy 4.1 pins with their respective submodules and channels
// FlexPWM(timer number)_(submodule)_(channel)
// FlexPWM4_2_A pin 2
// FlexPWM4_2_B pin 3
// FlexPWM1_3_B pin 7
// FlexPWM1_3_A pin 8
// FlexPWM2_2_A pin 6
// FlexPWM2_2_B pin 9
// FlexPWM3_1_B pin 28
// FlexPWM3_1_A pin 29
// FlexPWM2_3_A pin 36
// FlexPWM2_3_B pin 37
// BLDC driver instance
// make sure to provide channel A for high side and channel B for low side
// BLDCDriver6PWM(pwmA_H, pwmA_L, pwmB_H,pwmB_L, pwmC_H, pwmC_L)
// Example configuration
BLDCDriver6PWM driver = BLDCDriver6PWM(2,3, 6,9, 8,7);
// Enable debugging
// Driver init will show debugging output
driver.pwm_frequency = 30000;
// dead zone percentage of the duty cycle - default 0.02 - 2%
driver.dead_zone=0.02;
driver.voltage_limit = 12;
// driver init
// enable driver
driver.enable();
// setting pwm
// phase A: 3V
// phase B: 6V
// phase C: 5V
driver.setPwm(3,6,5);
Quick tip
We suggest using the SimpleFOCDebug in order to get a bit more information about the driver initialization. The debugging interface will output more information about the driver init procedure in the Serial and will let you know if some of the pins that you’ve chosen are not suitable for 6PWM.
In order to enable it add these lines before calling the driver.init().
// Enable debugging
As usual, the code has been tested and it outputs proper center-aligned PWM signal as well as correct dead-zone and pwm frequency provided by the driver.dead_zone and driver.pwm_frequency.
Let us know what you think.
