Teensy 3.x inital support for 6pwm
Hi guys,
The initial 6pwm support for Teensy 3.x and Teensy LC boards is in the dev branch
For now simplefoc will support one 6PWM driver per Timer (FTMx) so only the boards Teensy 3.5 and Teensy3.6 will be able to support 2 motors.
The support is a preliminary and it would be really cool if you guys can test it and let us know what you think. For the next release we will try to work our way to Teensy 4.x boards and to a more flexible 6pwm implementation.
Supported boards
For now simplefoc supports 6pwm for boards:
  • Teensy 3.0 - chip MK20DX128
    Teensy 3.1/3.2 - chip MK20DX256
  • Teensy 3.5 - chip MK20DX128
  • Teensy LC - chip MKL26Z64
  • Teensy 3.5 - chip MK64FX512 - two 6pwm drivers
  • Teensy 3.6 - chip MK66FX1M0 - two 6pwm drivers
Supported pinouts
We support only the hardware 6PWM mode, meaning that all 6 pins have to belong to the same timer. As all the teensy boards 3.x/LC have at least 6 channels on their timer FTM0, this is a safe and most standard implementation. All these boards have
  • FTM0_CH0 - 22
  • FTM0_CH1 - 23
  • FTM0_CH2 - 9
  • FTM0_CH3 - 10
  • FTM0_CH4 - 6
  • FTM0_CH5 - 20
Boards 3.5/3.6 have 6 channels of the timer FTM3 as well so that can additionally support 6pwm on pins:
  • FTM3_CH0 - 2
  • FTM3_CH1 - 14
  • FTM3_CH2 - 7
  • FTM3_CH3 - 8
  • FTM3_CH4 - 35
  • FTM3_CH5 - 46
Example code
There is an example code in the library examples folder that you can use to start off your applications.
// 6pwm standalone example code for Teensy 3.x boards
// BLDC driver instance
// using FTM0 timer
BLDCDriver6PWM driver = BLDCDriver6PWM(22,23, 9,10, 6,20, 8);
// using FTM3 timer - available on Teensy3.5 and Teensy3.6
// BLDCDriver6PWM driver = BLDCDriver6PWM(2,14, 7,8, 35,36, 8);
  // Enable debugging
  // Driver init will show debugging output
  driver.pwm_frequency = 30000;
  // dead zone percentage of the duty cycle - default 0.02 - 2%
  driver.dead_zone=0.02;
  driver.voltage_limit = 12;
  // driver init
  // enable driver
  driver.enable();
  // setting pwm
  // phase A: 3V
  // phase B: 6V
  // phase C: 5V
  driver.setPwm(3,6,5);
The code has been tested and it outputs proper center-aligned PWM signal as well as correct dead-zone and pwm frequency provided by the driver.dead_zone and driver.pwm_frequency.
Let us know what you think.
@Antun_Skuric
That’s great! Only one comment, the example code is for fixed PWM and I’ve seen quite a few people running it blindly and wondering why the motor doesn’t move. Perhaps in the future we could provide an open loop example so they don’t get confused.
You’re absolutely right. I’ve added a velocity openloop example in the library examples folder. It will be in the next release.
Here is a code example of how to use the 6pwm driver with Teensy 3x in the open loop velocity control:
// 6pwm openloop velocity example
// using FTM0 timer
// BLDCDriver6PWM(pwmA_H, pwmA_L, pwmB_H,pwmB_L, pwmC_H, pwmC_L)
  driver.voltage_limit = 6;
  // limiting motor movements
  // currnet = resistance*voltage, so try to be well under 1Amp
  // open loop control config
  // init motor hardware
  //initial motor target
  motor.target=0;
  // using motor.voltage_limit
