Subject: Open loop control not working with B-G431B-ESC1 in Arduino IDE — motor unresponsive
Hello everyone,
I’m having trouble getting open loop control to work with my B-G431B-ESC1 board.
The code compiles fine in Arduino IDE, but the motor doesn’t respond at all — no movement, no sound, nothing.
What I’ve tried so far:
  • Used SimpleFOCGenerator to generate open loop code for my motor.
  • Also tried known working open loop examples from other users (for the same board).
  • Double-checked all connections (power, motor phases, hall/encoder if applicable).
My motor specs:
  • KV: 1850
  • Poles: 7
  • Phase resistance: 0.4 Ω
  • Phase inductance: 0.1 mH
Setup:
  • Board: B-G431B-ESC1
  • IDE: Arduino IDE (with STM32duino and SimpleFOC installed)
  • Power supply: 12V (tested, sufficient current)
  • No load during testing.
The problem:
After upload, the board seems to run (LED on), but the motor doesn’t spin. I’ve tried varying the target value in open loop mode, but no response.
Questions:
  1. Are there known issues with open loop on B-G431B-ESC1 for very low inductance motors (0.1 mH)?
  2. Could timing/ PWM frequency settings be a factor?
  3. Should I modify voltage_limit or velocity_limit for this motor spec?
  4. Any specific openloop_gain or phase_resistance compensation needed?
  5. Is there a minimal working open loop example for this board that I can compare with?
I’ve attached my current code snippet below. Any help or guidance would be greatly appreciated!
Your code doesn’t seem to have posted. Try it again.
