I am using GIM4305 10:1 gear motor from Steadywin. It is run on 14.4v, Atmelsam custom driver, closed-loop with AS5047D encoder.
After every run it is changed to ME0. When I restart it, the motor is very noisy first 5-7 seconds. Then it starts running smoothly. It happens ever time.
If the motor is going back and forth in a loop, then it does not happen after every loop, only happens the first time it is activated ME0 > ME1.
Also, if you listen to the noise in video before the motor starts, there is some oscillation noise even when motor is on Zero, I somehow can’t get rid of it.
EDIT: I get that constant noise if I take it to 35rpm at 14.4v. On the other hand, the PID seems good with following output:
My PID values are as below:
motor.voltage_limit = 14.4;
//motor.current_limit = 1;
motor.motion_downsample = 5;
//motor.voltage_sensor_align = 1;
// need to be tuned
motor.PID_velocity.P = 0.17;
motor.PID_velocity.I = 1;
motor.PID_velocity.D = 0.0002;
motor.LPF_velocity.Tf = 0.085;
//motor.LPF_angle.Tf = 0.01;
//motor.PID_velocity.output_ramp = 1000; // lets keep this quite low!
Any suggestions?
