Hello, I’m trying to use a stepper motor in combination with the AS5600 but its doesn’t seem to be working correctly, I can’t figure out why.
// Stepper motor instance
// Stepper driver instance
StepperDriver4PWM driver = StepperDriver4PWM(10, 9, 6, 5, 11, 3);
// encoder instance
MagneticSensorI2C encoder = MagneticSensorI2C(AS5600_I2C);
// commander interface
// encoder initialiseren en linken
encoder.init();
motor.linkSensor(&encoder);
// choose FOC modulation
motor.PID_velocity.P = 0.2;
motor.PID_velocity.I = 20;
motor.voltage_limit = 12;
motor.LPF_velocity.Tf = 0.01;
// angle loop controller
motor.P_angle.P = 20;
// angle loop velocity limit
motor.velocity_limit = 50;
// monitoring port
// initialise motor
motor.target = 2;
// define the motor id
Thanks in advance.
Carelsbergh Stijn
