Hello comrades. I had not yet finished with the design of my steering wheel, as there was a wild desire to build a mobile platform. Today I tried a sketch from the example of step direction, for signaling I use the second arduino board. The pulses are applied every 100 microseconds, but the motor does not rotate. Please tell me, what am I doing wrong? By the way, my wife is very glad that I found you guys)))
* A position control example using step/dir interface to update the motor position
// encoder instance
Encoder encoder = Encoder(2, 3, 1024);
// channel A and B callbacks
void doA() { encoder.handleA(); }
void doB() { encoder.handleB(); }
// StepDirListener( step_pin, dir_pin, counter_to_value)
StepDirListener step_dir = StepDirListener(A4, A5, 2.0f*_PI/200.0);
void onStep() { step_dir.handle(); }
encoder.init();
motor.linkSensor(&encoder);
// aligning voltage [V]
// contoller configuration
motor.PID_velocity.P = 0.2f;
motor.PID_velocity.I = 5;
motor.voltage_limit = 5;
// angle P controller
motor.P_angle.P = 10;
motor.velocity_limit = 100;
// init step and dir pins
step_dir.init();
// enable interrupts
step_dir.enableInterrupt(onStep);
// attach the variable to be updated on each step (optional)
// the same can be done asynchronously by caling motor.move(step_dir.getValue());
step_dir.attach(&motor.target);
Serial.println(F("Listening to step/dir commands!"));
