This is almost working! I can get it to recover, but things are still not 100%. Code below. Here is why (I think):
I think the switch between modes needs some kind of filter otherwise even when in recovery mode, when the angles align it will temporarily switch back to openloop.
Either way, this speed limit is still a show stopper in recovery mode during which we are limited by the settings of the motor afaik.
And… as far as I gather empirically… under load I am reaching a limit in open loop. And even with no load, I reach a limit in closed loop.
I have not tested the recovery system on load, However, without load, I can see that past the closed loop velocity limit mentioned above, the recovery system gets wonky.
I think we are close. And some of these problems would get resolved with a sensor I assume.
Here is the code. Btw, with the following in loopFOC:
if (controller != MotionControlType::velocity_openloop)
electrical_angle = electricalAngle();
The sensor can remain linked to the motor so that it can be updated.
#include <SimpleFOCDrivers.h>
#include <encoders/MXLEMMING_observer/MXLEMMINGObserverSensor.h>
// Motor instance
BLDCMotor motor = BLDCMotor(7, 0.14, 2450, 0.00003);
// Gain calculation shown at https://community.simplefoc.com/t/b-g431b-esc1-current-control/521/21
// encoder instance
MXLEMMINGObserverSensor sensor = MXLEMMINGObserverSensor(motor);
float targetV = 0;
float targetP = 0;
float targetI = 0;
LowPassFilter targetFilter = LowPassFilter(2.0f);
LowPassFilter diffFilter = LowPassFilter(0.5f);
void doTargetV(char* cmd) { command.scalar(&targetV, cmd); }
void doTargetP(char* cmd) { command.scalar(&targetP, cmd); }
void doTargetI(char* cmd) { command.scalar(&targetI, cmd); }
if(!currentSense.init()){
Serial.println("Current sense init failed.");
return;
// no need for aligning
motor.sensor_direction= Direction::CW;
motor.zero_electric_angle = 0;
motor.torque_controller = TorqueControlType::dc_current;
motor.current_sp = motor.current_limit;
motor.PID_velocity.P = 0.01;
motor.PID_velocity.I = 0.004;
driver.voltage_limit = 2;
motor.voltage_limit = 1;
//motor.current_limit = 2;
motor.PID_velocity.limit = motor.voltage_limit;
//motor.PID_velocity.output_ramp = 1000;
//motor.LPF_velocity.Tf = 0.1;
motor.monitor_downsample = 10000;
//motor.motion_downsample = 4;
command.add('V', doTargetV, "target V");
command.add('P', doTargetP, "target P");
command.add('I', doTargetI, "target I");
motor.move(targetFilter(targetV));
//Serial.println(motor.shaft_angle);
int32_t sensorAngle = (int32_t)(sensor.electrical_angle * (32768.0f/_PI));
int32_t openloopAngle = (int32_t)(motor.electrical_angle * (32768.0f/_PI));
int16_t diff = (int16_t)(sensorAngle - openloopAngle);
static uint32_t lastPrintTime = millis();
if (millis() > lastPrintTime + 250) {
Serial.print("\t");
Serial.print(sensorAngle);
Serial.print("\t");
Serial.print(openloopAngle);
Serial.print("\t");
Serial.print(diff);
Serial.print("\t");
Serial.println(motor.controller);
if ((diff > (32768/6) || diff < -(32768/6)) && motor.controller != MotionControlType::velocity) {
//Serial.println("here1");
} else {
//Serial.println("here2");
//motor.monitor();
