I am a bit lost following the setup page for simpleFOCstudio. Is this the correct starting point for code before running the simplefocStudio the first time?
if so i am getting a compiler error as follows.
error: ‘motor’ was not declared in this scope; did you mean ‘doMotor’?
// include commander interface
void setup(){
// add the motor to the commander interface
// The letter (here 'M') you will provide to the SimpleFOCStudio
command.add('M',doMotor,'motor');
// tell the motor to use the monitoring
motor.monitor_downsample = 0; // disable monitor at first - optional
void loop(){
// real-time monitoring calls
// real-time commander calls
additionally when running command prompt python simplefocstudio.py i get the following.
libpng warning: iCCP: known incorrect sRGB profile
