SmoothingSensor: Experimental sensor angle extrapoltion
This is at constant target voltage, smoothing is off then on then off
I played around with the phase_correction but it doesn’t seem to be the problem.
Could my motor.shaft_velocity be bad ? I understood it’s low pass filtered, but it looks quite noisy. maybe because of the scale.
[EDIT] tweaked LPF_velocity and tried velocity mode with the following parameters, but it’s still not smooth with the smoothing
motor.PID_velocity.P = 0.6;
motor.PID_velocity.I = 5.0;
Sorry I am still discovering some of the aspects of simplefoc that took from granted in other motor control firmware
Honestly I would say just forget about the smoothing unless you want to work on it for the benefit of others. That motor seems to run very nicely as is.
I suspect that velocity variation is what we’re hearing in the video. Perhaps a feedback effect because the extrapolation feeds the velocity variation into the voltage angle, which causes variation in torque and thus more variation in velocity. You could try increasing the time constant on the velocity low-pass to damp it out.
Sorry I was editing my message at the same time.
Tried velocity mode but the smoothing was still noisy.
I am happy to help with this.
I had suggested here a calibration procedure that could possibly help with hall sensors that are not evenly placed. Here is an example I saw on a forum (Yellow to purple is 2 squares, blue to yellow 1.5)
But I don’t think that’s the issue here. I will investigate more.
Yeah, try higher Tf. I use .05.
I agree hall placement shouldn’t be an issue in this case, considering that they’re stuck into notches in the stator teeth, and the overall dimensions are large. Much harder to get perfect positioning on small motors, where the sensors are comparable size to the stator teeth, and you can’t get them as close to the magnets as you’d like because the coils are in the way.
I have the feeling your extrapolation is ok but speed estimation on that kind of motors is complicated.
I think the hoverboard firmware is using the timestamps of last 4 hall position change to estimate the speed, so a strong filter.
So after inverting the sign of 2 variables it works quite well, the motor is more silent.
But now there is something else I don’t understand, probably I am doing a mistake somewhere.
I initially started to test the hoverboard controller with my gd32 driver code using trapezoidal120.
SinePWM seemed more silent but much slower, I thought it had to do with the missing smoothing.
Now SinePWM with smoothing is even more silent but is still much slower than trapezoidal.
And it’s all consuming more than trapezoidal while being slower ?
During my tests driver.voltage_power_supply = driver.voltage_limit.
I am increasing the target until I feel it’s saturating.
15/16 KV seems correct for a hoverboard motor.
Any ideas are welcome.
I mentioned this in our PM conversation, but for others reading, the sign inversion most likely means that velocity and phase_correction need to be multiplied by motor.sensor_direction when performing the angle prediction.
The speed chart is interesting. SinePWM without smoothing should produce more or less the same output as trapezoid120, because the electrical angle only changes when the hall state changes. Although trapezoid does have those driver->setPhaseState calls to disable the third phase. Maybe that’s what makes the difference?
If you want to run another test, I’m curious to see what you get with SmoothingSensor.phase_correction = 0. I thought it would cause field weakening and excessively high speed, but maybe it’s the opposite and un-smoothed sine has the phase shifted somehow, causing it to spin too slow and with poor efficiency?
0,52 should be Pi/6.
0,35 is the sweet spot, it’s quiet and faster than before ( still slower than trapezoidal), and consumes less.
Then from 0,3 to 0,25 it gets a bit noisier, but it’s not due to pitch/speed.
From 0,20 it’s clearly phase advance/field weakening.
Could my zero_electrical_angle be off ?
[EDIT] Yep, I think it was off by 0,17 something… :person_facepalming:
It seems to impact trapezoidal and sinusoidal differently.
No it’s worse than that. Sorry for all the spam.
Using 1.92 as zero_electrical_angle instead of 2.09 was working in one direction, but making things worse in the other direction. I had to apply the opposite shift in the other direction to get the same effect (2.26).
But it works in both directions when I only shift the phase_correction from 0.52 to 0.35.
And interestingly, that 0.35 phase correction is right only at maximum target.
The sweet spot moves from 0.52 to 0.35 as the target increases.
Am I rediscovering the Maximum Torque per Ampere concept lol
[EDIT] Hmm I knew I saw this somewhere, I only found it now. Maybe this will help
Nice, so it looks like phase correction around 0.17 should give similar RPM and current as trapezoid120, so it is only an effective phase difference and nothing fundamentally different about trapezoid mode… and means that trapezoid may be doing some undesirable field weakening, so that should be investigated at some point.
I had to manually adjust the zero angle on mine too (I just change it until max speed is the same in both directions), but I thought it was only due to the stator being rotated a few degrees relative to the sensors on the motor I was testing with (machining error).
Were you restarting and running the auto-calibration for each test in post #26? Given the random variation in min/max speeds regardless of smoothing enabled or not, I’m starting to think the auto-calibration doesn’t work well for hall sensors, giving a random value within ±30 degrees of where it should be rather than finding the exact center of the hall state or transition point between hall states (I’m not sure which it should be).
@dekutree64 I think your interpolation is totally fine, and the value of the phase_correction is also fine.
I first thought the zero angle was a problem but min/max speeds are pretty close.
The problem is not the rotor position, your interpolation estimates it well.
The problem is that as the speed increases, the target vector is not at 90 degrees anymore.
I did a quick test adding the inductance parameter for lag compensation and it was promising.
I will update the table I shared earlier with the different commutations/speed/consumption.
It’s true that the current calibration is not optimal for hall sensors, but I am happy to help with this if you are interested. Having the hall state start/middle/end will also help having a smoother velocity thus a better velocity control.
[EDIT]
SinePWM and SVPWM are much quieter with your extrapolation, and it only slighty increases the speed so phase_correction is ok, no field weakening.
With the lag compensation, consumption is divided by 2 with a higher speed.
SVPWM is faster than SinePWM as you can use a higher voltage limit and target, but still slower than trap120.
I haven’t collected the consumption in both directions, but although the speed is close, there are gaps in consumption.
I probably need to tweak the zero_electrical_angle as I kept the value from the calibration. The inductance parameter could also not be optimal.
now that the smoothingSensor is back in focus, I’d like to ask a few questions:
  1. In the beginning it was about PWM sensor smoothing, but later it was about (linear or digital?) hall sensors…
    What sensor types are supported now?
  2. Is it included in sFOC 2.3? There don’t seem to be any examples?
    [That’s an indirect hint, that some included stone-age examples could use a face lift…but that’s OT]
  3. the dead point in my application is most visible at slow RPM.
    Is there a way to tune smoothing for low RPM?
Please let me know if there’s a summary of all that in the docs.
No, it will be in the drivers library, in the next release.
It has docs in the form of a README in its folder:
And it actually has an example too:
of course at the moment these things are still on the dev branch.
If/when SmoothingSensor becomes so stable that everyone wants and uses it we’ll move it to the main repository. But for the moment, it is part of the more “experimental” code in the drivers library.
In the readme there miiiight be an error?
SmoothingSensor smooth = SmoothingSensor(sensor, motor);
// should be *(&sensor, &motor)* , right?
Just out of curiosity I tried to compile the example for an UNO, halfway expecting the code to be too big. But I already stumbled over the Pci_Manager? :frowning:
It will work with any sensor, but is meaningless on anything with high resolution and fast communication. Assuming you’re referring to janosh85’s thread, he is using digital halls now and therefore it may be helpful.
Yeah, writing documentation is not one of my strong points. And I have minimal hardware to test on, so the examples are mostly copy/paste with the few relevant lines added to show the proper usage pattern.
I always get that Pci_Manager error too, but figured it was just a problem with my environment. I never really looked into it.
Increasing the velocity filter constant can help extend the low end. At least with hall sensors, the motor tends to move in steps at low speed, so the velocity alternates between high and low. By filtering it, you get a more constant velocity reading despite the jerky motion, which results in a smoothly increasing predicted angle, which drives the motor to produce smoother true velocity, creating a happy feedback loop.
But for very low speed, I need to try again at the pseudo-open-loop mode.
No, the version on github uses references rather than pointers like the original from the thread. I matched it to the style of CalibratedSensor because it was there first.
Thanks for the clarifications… I can be a smarta$$ sometimes
Turns out, the Pci_manager is a separate library. I just installed V2.1.4
Now I run into smoothingSensor.h not found.
Guess I have to use the sFOC_driver release of the dev-branch …although it is also labelled V1.0.4 ?
Even with #include <encoders/smoothing/SmoothingSensor.h>, not just #include <SmoothingSensor.h>? Make sure the file is actually there on your hard drive. It should be a separate library Arduino-FOC-Drivers, not in the main Arduino-FOC folder.
Yes, that’s the right include but you also need to be on the dev branch of the drivers library and the SimpleFOC library…
That means removing the automatically downloaded version and replacing it with the dev branch version from GitHub.
Both dev branch of SFOC and SFOC drivers should be used.
