First, and I wish I would have included this in my original post, I think this community and the support from everyone is extremely helpful and is really appreciated!
I did some more reading after posting, and I saw a posting about the solder pad configuration:
and it looks to me (see attached image)
like the board i received is configured as suggested, so i understand the BLDCDriver3PWM pins set to (9,5,6,8)… i hope i’m understanding that correctly
i reset the DIP settings in the AMT103_V to (0,0,0,0) which corresponds to 2048 PPR and re-ran the SimpleFOC library example codes.
the encoder_example works fine and shows positions ±6.28 with a full turn in each direction
the open_loop_velocity_example appears to run correctly
the open_loop_position_example appears to run correctly
the torque example current_control gets me a “too big to load” error for my arduino R3
the torque example voltage_control appears to partially work, but seems unstable with motor vibrations and reversals of direction
my code for the closed-loop example for angle_control is included below. when i run it, the motor starts turning on its own, if i set a target angle it will settle into a large and rough oscillation around that value, and sometimes that mode then breaks out into a constant rotation, so it appears that it’s trying to work, but has an instability…
i measured the resistance between the three phase leads and got 10.7, 9.9, and 9.2 ohms… i seem to recall those should all be equal???
thanks for the help!
- Position/angle motion control example
- Steps:
- Configure the motor and encoder
- Run the code
- Set the target angle (in radians) from serial terminal
- NOTE :
Arduino UNO example code for running velocity motion control using an encoder with index significantly
Since Arduino UNO doesn’t have enough interrupt pins we have to use software interrupt library PciManager.
If running this code with Nucleo or Bluepill or any other board which has more than 2 interrupt pins
you can supply doIndex directly to the encoder.enableInterrupts(doA,doB,doIndex) and avoid using PciManger
If you don’t want to use index pin initialize the encoder class without index pin number:
For example:
- Encoder encoder = Encoder(2, 3, 8192);
and initialize interrupts like this:
- encoder.enableInterrupts(doA,doB)
- Check the docs.simplefoc.com for more info about the possible encoder configuration.
BLDCMotor motor = BLDCMotor(8);
// encoder instance
Encoder encoder = Encoder(2, 3, 2048);
// channel A and B callbacks
// angle set point variable
float target_angle = 0;
encoder.init();
motor.linkSensor(&encoder);
driver.voltage_power_supply = 7.4;
// aligning voltage [V]
// contoller configuration
motor.PID_velocity.P = 0.2f;
motor.PID_velocity.I = 20;
motor.voltage_limit = 6;
// angle P controller
motor.P_angle.P = 20;
motor.velocity_limit = 4;
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
motor.move(target_angle);
// motor.monitor();
